Better Than Nothing---The rebirth of a Superbike.
- Online
Re: Better Than Nothing---The rebirth of a Superbike.
09 Sep 2018 13:25
Good for you Bob !!!
Now rub some aloe on your bald head and relax.
09 Sep 2018 14:57
Congratulations!
Even though two bikes did not win a trophy, they may inspire a younger enthusiast to save another old bike.
09 Sep 2018 14:58
Perhaps we should start a Dr. Gamma hat fund.
- Dr. Gamma
09 Sep 2018 15:59 - 09 Sep 2018 16:03TexasKZ wrote: Perhaps we should start a Dr. Gamma hat fund.
I had my old Schumacher hat on as we loaded up the truck. At the bike show site, I didn't put my hat back on. We stood around outside with other members and bull shitted for about an hour and a half before we unloaded. By then my head was fried!!!!! I bent over to loosen the tie downs and I about passed out!!! The 92 degree heat, the fried head, and not eating did me in for the rest of the day!!! I drank 5 bottles of Gatorade and a water in 5 hours.
It only takes about 15 to 20 minutes before you start to burn in the Arizona sunshine!!! An hour and a half you are a red lobster!!!
1986 RG500G 2 stroke terror.
Last edit: 09 Sep 2018 16:03 by Dr. Gamma.
- Dr. Gamma
09 Sep 2018 16:18
Here is a distance shot of my three bikes at the VJMC bike show yesterday. Look behind the Suzuki Rotisserie and you can see the Superbike with the GSXR and the Gamma next to it!!!
- bluej58
09 Sep 2018 16:42
Congrats Doc, did you get to fire her up?
78 KZ1000 A2A
- Dr. Gamma
10 Sep 2018 10:11 - 10 Sep 2018 10:54..bluej58 wrote: Congrats Doc, did you get to fire her up?
Unfortunately no.
I was feeling so bad by the time we got the bikes out of the truck, I had a hard time just walking to the display area!!!
You can see me with my hat on sitting on the bench trying to get myself to feel better!!!
The winning Kawasaki at the West Coast Rally!!
My GSXR750RG on display at the West Coast Rally show
Last edit: 10 Sep 2018 10:54 by Dr. Gamma.
- Dr. Gamma
05 Nov 2018 14:27
This photo is for bluej58. This is the clutch release you are looking for!!! It is a bolt on part for your bike. This is the best clutch release that Kawasaki ever put in their 900/1000's!!!!
- bluej58
05 Nov 2018 14:50
No eBay APP ID and/or Cert ID defined in Kunena configurationCool! thanks Bob, scored a filthy one off of flea bay, taken off a 80 kz550
They list a bunch of bikes that it will fit but no 1000's , looks the same though, fingers crossed.
78 KZ1000 A2A
- Dr. Gamma
05 Nov 2018 15:49
They list that release to be the very same part number, 13231-020. So it should fit no problem!!!
Just make sure you repack it with some good hi-temp grease after you get all the old grease, and grit that has accumulated in that release out of it!!!
- bluej58
05 Nov 2018 16:05
So you say that it has ball bearings that I don't want to deal with, what is the best way to clean it? soak it in gas?
78 KZ1000 A2A
- Dr. Gamma
05 Nov 2018 16:59
I cleaned mine in the past with Safety Kleen. Any solvent like gas would do. Then spray some carb cleaner through it to make sure there is no more grit inside of it. Just check it when you get your release and see if you can feel any grit inside of the release. If not just repack it. The hardest thing is to get grease all the way through the whole release. I have used that spray grease to get all the way into the release.
I never had the patience to take one of those releases apart. I found it easier to just replace it with a new one. But that was back in the day when you could still buy them from Kawasaki, and I had extra money to spend!!!
