Subframe help/ideas wanted
  • kzz1king
  • kzz1king's Avatar Topic Author
30 Jan 2013 00:51
#569887
First off do not laugh too hard at my high tech artwork! I want to build a new subframe if that is the correct terminology. Anyhow the backhalf of the frame. I mono shocked the frame and want to build or purchase a tail/seat like this unit.
Attachment wrenchmonkee.jpg not found
In my blueprint(part of it is blue) the larger is stock and the smaller is what I am thinking of doing.
Question 1-How does one address area B after removing that tube?
2- How far down and out does the brace need to be (see red ?)
3- What type of material is used?
Attachment DSCN2190.JPG not found
THANKS
Wayne
Home built KZ1000 turbo setup
  • wireman
  • wireman's Avatar
Re: Subframe help/ideas wanted
30 Jan 2013 01:06
#569892
didnt dutch's z1 have a custom rear sub frame of some sort?
Havent seen him on in a while B)
  • bluezbike
  • bluezbike's Avatar
30 Jan 2013 02:16
#569901
Wayne, have a look at Arnold's Retro Fighter 2.0 build, he deals with the issues at point B in a very cool way and has some subframe ideas too. Look in the projects section.
Good going,
Alec
79 KZ 1000 LTD
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
30 Jan 2013 12:24 - 30 Jan 2013 12:34
#569947
wireman is right sander (dutchz)did some real nice subframe work on his bike.
it can be as simple as a triangle,
but the lower support tubes need to be behind your a$$ to properly support you.
if you plan to have a passenger the lower tubes need to be behind the passengers a$$.
the slickest i have seen area "b" capped is by bending tubing to make the radius and then cut a section out of the bent tube and weld it in and blend it out.
like arnold did :) ,
Last edit: 30 Jan 2013 12:34 by 531blackbanshee.
  • kzz1king
30 Jan 2013 13:21 - 30 Jan 2013 13:25
#569950
Thanks guys! Arnolds stuff is killer. I like the way he handled point B. I could maybe do that if I could source the bends. Thanks for the input on butt placement Leon! Going to be a single seater.
I assume triangulation will be strongest if supporting tubes are at 45 degrees or less?
Wayne
Last edit: 30 Jan 2013 13:25 by kzz1king.
  • 531blackbanshee
  • Vendor
  • Vendor
30 Jan 2013 14:11
#569956
the lower tube is in compression,so it is going to be very strong.
i would use 1" .065 wall thickness 4130 chromoly if it were me (because that is what i use on everyting :) ).
but some nice 1" d.o.m. would be sufficient.
www.shapirosupply.com/index.php?main_pag...45738109aec79fdf8075
i would use the same size tubing top and bottom.
hth,
  • 531blackbanshee
  • Vendor
  • Vendor
30 Jan 2013 16:00
#569971
a lil inspiration :) .
  • kzz1king
30 Jan 2013 16:22
#569974
YOWSA :cheer:
  • 893cv
  • 893cv's Avatar
31 Jan 2013 17:09
#570112
Nice 750, very well done.
1980 kz1000 LTD
1978 Z1R
  • ramtough_63
  • ramtough_63's Avatar
31 Jan 2013 18:35
#570131
now that is SEXY
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
