Painting carbs?
  • apbling
  • apbling's Avatar Topic Author
Painting carbs?
03 Mar 2011 08:52
#434625
I have an 82 550 ltd with tk22 carbs (they seem to be a mg of zn body, not aluminum?) and a 1980 750-4 with Kehien cv34's (these seem to be aluminum). Both bikes are cleaned and polished to look great, but I'm having trouble with the carbs. They are hard to polish because of the small grooves and such, plus the ones on the 550 just don't shine up well. I was thinking of throwing a coat of paint on them, kind of like the gpz's have, but silver.
Any advice on this? I'm worried it'll peel, look like hell and possibly gum things up. Plus, I'll most likely scratch them up putting them in... but still thinking about it.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Painting carbs?
03 Mar 2011 09:01
#434628
im guessing theyre both die cast.
never tried painting carbs .seems like a major especially the first time you got gas on them,how about powder coating the bodies? B)
  • apbling
Re: Painting carbs?
03 Mar 2011 09:07
#434632
ah, that would be a better idea... :)
  • DoubleDub
  • DoubleDub's Avatar
Re: Painting carbs?
03 Mar 2011 09:07
#434634
Just let them get oxidized and gunky. Then they'll look perfect. :)
Re: Painting carbs?
03 Mar 2011 10:05
#434646
Painting is discouraged by wiredgeorge:
Click > www.wgcarbs.com//index.php?option=com_co...view&id=19&Itemid=35
Powdercoat will also discolor from gasoline dripage.
Might investigate Gun-Kote as another option.
Good Fortune! :)
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Painting carbs?
03 Mar 2011 11:04
#434667
Good Fortune! :)
The powder coat does still get screwed by gas if you dont get at it real quick, to that I can attest.
I have painted my carbs with regualar chassis/rollbar paint and a gas resistant 2-part clear. They look great, but the outside two need a touchup once in a while because of rubbing, debris, crud from the road - you know. Nothing major.
Oh yeah - best to make sure your carbs dont piss gas first! C'mon! :laugh:
Good luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • martin_csr
  • martin_csr's Avatar
Re: -
03 Mar 2011 13:45 - 11 Feb 2013 13:21
#434723
Last edit: 11 Feb 2013 13:21 by martin_csr.
  • DoubleDub
Re: Painting carbs?
03 Mar 2011 13:47
#434725
You guys are too much - I just want mine to feed fuel/air and make the bike go vroom.
  • martin_csr
Re: -
03 Mar 2011 14:04 - 11 Feb 2013 13:22
#434735
Last edit: 11 Feb 2013 13:22 by martin_csr.
  • TeK9iNe
  • TeK9iNe's Avatar
Re: Painting carbs?
03 Mar 2011 14:18
#434743
martin_csr wrote:
The carbs below were done by someone here on KZR several years ago.
I believe it's an electroless nickel plating, perhaps more commonly used on guns or something. It's neato.
Looks like only the bowls were done...?
I did the opposite: Painted carb bodies/rails gloss black, then polished the caps and bowls super shiney chrome like.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • martin_csr
Re: -
03 Mar 2011 16:33 - 11 Feb 2013 13:21
#434773
  • peter1958
  • peter1958's Avatar
  • Banned
  • Banned
Re: Painting carbs?
03 Mar 2011 17:47
#434785
I would go look at the kz1000r site and see what they use. Just my 2 cents. Those carbs are black from factory
