79KZ650 "custom" muffler center pipe
- LineArtist
02 Jun 2014 17:45 - 19 Jun 2014 04:34
The exhaust center pipe on my '79 was cracked open on the left and soon afterwards broken off on the right. Ideally a new exhaust would be great, but I'm determined to get the bike on the road with minimal replacement parts. I reviewed several suggestions here on the forum including the copper pipe macgyver which I attempted but will not pursue.
I took it all apart and will be sending it out to a performance muffler shop to have them weld on a new center pipe. I'm going to request a clamped connection in the middle, mostly likely 1" pipe going over top of the old nubs.
I decided to mock-up the system on the floor of my garage so they would have the correct geometry to work with or I could wait a another week and ride the bike over (nah). I made 3 wood spaces to set up the mock-up.
this is the B spacer, simply get a tight fit and add an alignment strap to the bottom
used a piece of cardboard to get the impressions of 4 of the manifold screws (they are equal to the center spacing of the pipes)
used my drill press to cut out the C spacer
muffler spacer A
A, B and C (I went back to C and added a stop board on the inside to prevent the pipes from sliding through, it also helps with the pivot angle and stabilizing the rig)
the mock-up using bungee cords to keep it all together
- A. spacer at the muffler brackets measuring 10 1/2", with a 1/4" dowel on each end to set with the bolt hole
- B. mid span spacer, between the pipes, towards the front using the exhaust screws (drains?) as a guide.
- C. manifold bracket, 4 x 1-3/4" holes spaced to match block spacing (1)3-3/16"(2)3-5/16"(3)3-3/16"(4).
Attachment IMG_2490.jpg not found
Attachment IMG_2498.jpg not found
Attachment IMG_2501.jpg not found
Attachment IMG_2504.jpg not found
Attachment IMG_2502.jpg not found
Attachment IMG_2507.jpg not found
'79 KZ650B3 (stock)
'79 KZ650B3 (parts bike)
'06 HD 883R
'06 HD 883R
Last edit: 19 Jun 2014 04:34 by LineArtist.
- P21
Re: "custom" exhaust center pipe
02 Jun 2014 18:55
its hard to tell but is there a cross over pipe before mufflers?
Kawasaki KZ 1000 Police (2002) P21
- LineArtist
Re: "custom" muffler connector pipe
02 Jun 2014 19:18 - 02 Jun 2014 19:26Yes, it has rusted out and the reason I'm having a new one welded in.P21 wrote: its hard to tell but is there a cross over pipe before mufflers?
Attachment IMG_2461.jpg not found
'79 KZ650B3 (stock)
'06 HD 883R
'06 HD 883R
Last edit: 02 Jun 2014 19:26 by LineArtist.
- LineArtist
Re: 79KZ650 "custom" muffler center pipe
19 Jun 2014 04:47 - 19 Jun 2014 04:53
Just picked up the exhaust last night from the shop. And had enough time to loose install the pipes back on the bike
The new muffer center pipe is a 1-1/2" exhaust with a sleeve/clamp connector at center. There is about 1/2" travel to both sides in the sleeve to allow for adjustment. The exhaust manifold is currently loose connected at # 2 and #3 and I used a come-along to hold up the tail pipes in position alongside the brackets.
I checked underneath and measured about 1/4" clear under the oil filter cap. Since the old muffler center pipe was never on this bike I don't know how far down from the pan/filter it actually sat originally. I'll pull the exhaust off tonight to get at the oil filter cap and install a missing spring in the oil filter assembly. I'm also considering shaving down 2 of the fins on the oil filter cap in order to increase the clearance to 1/2". I understand the fins are there to add rigidity to the cap but don't see a problem knocking off the corner to just above the surface of the cap.
Also since this center pipe is more rigid, I'll loose attach the muffler brackets to the pipes first and then mount the brackets to the frame to add more adjustment to the system.
Sometimes you just need a second pair of hands.
Attachment IMG_2632.jpg not found
Attachment IMG_2633.jpg not found
Attachment IMG_2636.jpg not found
'79 KZ650B3 (stock)
'06 HD 883R
'06 HD 883R
Last edit: 19 Jun 2014 04:53 by LineArtist.
