Going to buy a 440 - what should I look at?
- splazoid
22 Feb 2012 05:00 #505608
by splazoid
Going to buy a 440 - what should I look at? was created by splazoid
Im going to be taking a look at buying an 81 KZ440 (chain version I believe?).
Im relatively technical and have worked on bikes before - what should I analyze about this model specifically? What's known to fail?
It's a craigslist find - seller says the motor runs smoothly, but sometime last year something happened so that the bike no longer runs under it's own power. I don't think that means the motor dies, but perhaps is clutch related.
Im planning on analyzing the usual, tires etc. and compression test - what else?
How can I try to field-diagnose what might need to go into this bike?
How much could I get for it parted-out if I can't save her?
Thanks!
Thanks!
- Thank you received: 2103
22 Feb 2012 09:48 - 22 Feb 2012 09:49 #505619
by Patton
Replied by Patton on topic Going to buy a 440 - what should I look at?
Original air-box would be a plus.
Absence of original air-box would be a minus.
Last edit: 22 Feb 2012 09:49 by Patton.
- Thank you received: 1646
22 Feb 2012 10:24 - 19 Feb 2013 14:13 #505627
by martin_csr
Last edit: 19 Feb 2013 14:13 by martin_csr.
- ramtough_63
22 Feb 2012 10:38 #505631
by ramtough_63
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Replied by ramtough_63 on topic Going to buy a 440 - what should I look at?
anytime you buy a non running bike it's a crap shoot in 2004 i bought a buddy of mine an 80's 440 so he could go ride with me.
That little bike was a workhorse. my buddy rode it rain shine snow everywhere to and from work was over 60 miles As he was not mechanical he didnt have to be.
the only things we did was put some Sportster shocks on the rear the factory shocks were weak when riding 2 up. and the gas tank was rusty when he got it and eventually rusted completely out.
it has sit for the last 2 years but I got 20.00 put a battery in it a decent tank with new gas and he would be riding this afternoon so
Buy it You will get it running and have a little workhorse.
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- KZJOE900
- Administrator
Super Users
22 Feb 2012 10:52 #505635
by KZJOE900
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Replied by KZJOE900 on topic Going to buy a 440 - what should I look at?
If you get good compression, than you are pretty solid. The main thing I would look for after that would be if it has a clear title. Don't know about WI, but in some states its a real pain to fix that. Next, I would make a list of what is missing, therefore you should take a list with you of what to check to make sure its there (e.i. air box, all the turn signals, fenders, and so on). I know that may sound silly, but I can't tell you how many times I had to go to Z1E or the internet to purchase odd parts and they can add up into the hundreds. Even if the parts are there, depending on their shape and your standards (un-salvageable rusty parts, etc) they may need replacing. Take that into consideration wit regards to price. What shape is the belt, and tires? The tires most likely need replacing. But if he tells you they not too old and look new, then that is a big plus. Good luck.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- mtkawboy
22 Feb 2012 20:15 #505701
by mtkawboy
Replied by mtkawboy on topic Going to buy a 440 - what should I look at?
Its a whole lot cheaper to buy a good running bike. I dont know about other places but in Montana a 440 has zero value, running or not. Id move up to a 750 or 1000, easier to sell & get parts for, just my opinion, others may vary
- DaddyJama
22 Feb 2012 22:45 #505753
by DaddyJama
2005 636 - track bike
1982 kz440ltd - new toy;)
Replied by DaddyJama on topic Going to buy a 440 - what should I look at?
I didn't know the difference between an ltd bs a regular 440 till I got it home. The frames are different.
- loudhvx
- Thank you received: 1622
23 Feb 2012 00:06 #505807
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Going to buy a 440 - what should I look at?
the carbs have diaphragms on top. If they are torn, the bike may idle, but not rev. The diphragms/slide parts cost over $100 each and there are two. You can get some aftermarket ones, sometimes $40 a pair, but they require some work to replace and don't always turn out perfect.
1981 KZ550 D1 gpz.
Other links.
- splazoid
23 Feb 2012 12:21 - 23 Feb 2012 12:22 #505901
by splazoid
Replied by splazoid on topic Going to buy a 440 - what should I look at?
Look what followed me home
$180 with title and clymer manual, and I even got it to engage in gear with a clutch cable adjustment.
Attachment 02-22-12_1715.jpg not found
Last edit: 23 Feb 2012 12:22 by splazoid.
- KZJOE900
- Administrator
Super Users
23 Feb 2012 14:36 #505931
by KZJOE900
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
You made out well Splazoid. Looks like everything is there. Even the air box. You are way ahead of the game in that regard. And for the price, you got a very good bargain, can't go wrong. Looks like a chain drive. You would be amazed how much better it looks like after your first wash (try simplegreen).
Congratulations!
Congratulations!
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- munkybrain2010
- Clueless..
23 Feb 2012 17:16 #505954
by munkybrain2010
Keep it together man!
79 KZ650 "Geto Cycle"
Replied by munkybrain2010 on topic Going to buy a 440 - what should I look at?
cGood find! doing the whole ten yards of clutch adjustment in the manual may even go further and takes about ten minutes.
- TomW
- Keep the blue side up.
- Thank you received: 52
23 Feb 2012 18:17 #505963
by TomW
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
Replied by TomW on topic Going to buy a 440 - what should I look at?
Great find!
I want one too. :laugh: How many miles on it? What part of WI are in? There are at least 2 KZR members in Mad City. I'm in West Bend. Get that thing runnin' and join the N. American Relay Ride.
