Engine Temperature
  • KZJAKE
  • KZJAKE's Avatar Topic Author
Engine Temperature
26 May 2010 21:27 - 27 May 2010 15:01
#371259
Any one know how hot should a KZ 650 engine get. I check mine after a 10 mile ride as soon as I shut it down. It was about 270 degrees on the head and about 200 on the crankcase. So is this right or what? The outside temp was about 85 degress.
Last edit: 27 May 2010 15:01 by KZJAKE.
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Engine Temperature
27 May 2010 06:36
#371304
What's the outside temp (Ambient)?
Can be as reviewed in recent testing here in AZ on my KZ.
Pre & Post synthetic oil and oil cooler....
Maybe will give you some idea on yours...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • BSKZ650
  • BSKZ650's Avatar
27 May 2010 06:58
#371311
cool chart OMR, but damn,, you have wayyy to much time on your hands..:)
77 ltd1000, current rider
76 kz900, just waiting
  • bountyhunter
  • bountyhunter's Avatar
27 May 2010 11:15
#371372
I read that the spark plugs are like thermostats. If you install a cooler plug, the head will run cooler.
  • bhardy501
  • bhardy501's Avatar
27 May 2010 11:22
#371376
I have thought about an engine oil cooler for my 80 kz1000. How hard are they to install and where do they install at?
1980 KZ1000B LTD
  • hocbj23
  • hocbj23's Avatar
27 May 2010 11:28
#371381
On my 1982 KZ 1000 it is installed on the frame where the horns used to be.Relocated the horns.Took me and a buddy about an hour to get it on.Old Kaw Man has a complete unit u can buy for 150 bucks or so-cooler,hoses,fittings ,etc.Good deal.bj
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
27 May 2010 11:38 - 27 May 2010 11:39
#371384
The oil cooler units are a totally un-necessary upgrade to even a moderately tuned motor (like pods + 4-1 with re-jetting).
If your going bigger block, extra lift cams, extra, extra, blah... Then you might really want to consider one.
EITHER WAY, start with one of these:
Not too expensive for peace of mind, from American Classix
It replaces your oil filler cap! Cool, I know! :P
Then you can see if you ever need an oil cooler upgrade.
Peace.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 27 May 2010 11:39 by TeK9iNe.
  • BSKZ650
  • BSKZ650's Avatar
27 May 2010 14:24
#371428
Tek,, I have to dissagree with you, I have coolers on my bikes, as of right now the outside temp is 92 degrees, and this is not even summer time.
You can feel the heat coming off the engine and any time you have a oppertunity to reduce the oil temp I would take it, unless you live in a cold climate.
I was riding Monday, and at lights I really noticed the heat.
  • hocbj23
  • hocbj23's Avatar
27 May 2010 15:34
#371447
x2.bj
  • bountyhunter
27 May 2010 16:25
#371456
Oil coolers were pretty essential in the days before syn oil, but the new oils and additive packages stand up to more temp than the engine can handle. I don't think a cooler is needed if you use the best oil.
  • Kawickrice
  • Kawickrice's Avatar
27 May 2010 16:41
#371462
Being from Florida the oil cooler is a piece of mind knowing the oil is getting some extra cool air. The only downfall I see is on cold startups the oil drops to the pan and it takes a while to get the lube going up to the cooler. These bikes run low oil pressure anyways .
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • davel
  • davel's Avatar
27 May 2010 19:44 - 27 May 2010 19:48
#371510
270 on the head and 200 at the crankcase (engine oil temp) are normal for an air cooled engine.
Temps can get to about 350 at the head and 250 at the crankcase without issue. Above that and you'll start to get signs of overheating. pinging, eratic idle, stalling at idle, or worse...
btw have a look at the picture Tek posted. That's a crankcase oil temp gauge. Note the red line at 250...
Last edit: 27 May 2010 19:48 by davel.
