KZ/GPZ mono shock hack was Budget Turbo Build
  • kzz1king
  • kzz1king's Avatar Topic Author
Re: KZ/GPZ mono shock hack was Budget Turbo Build
24 Mar 2013 22:48
#578655
I have not did any prettying up yet. Gonna grind it down and plastic dip the brake pedal I think.
Attachment DSCN2415.JPG not found
Attachment DSCN2414.JPG not found
Home built KZ1000 turbo setup
  • kzz1king
07 Apr 2013 17:33
#581050
I got the battery box made, Styrofoam battery is done, underseat wiring compartment and shortened the seat/tail assembly a bit. I think I am ready to strip it all down now.
Wayne
Attachment DSCN2462.JPG not found
Attachment DSCN2468.JPG not found
Attachment DSCN2471.JPG not found
Attachment DSCN2458.JPG not found
  • kzz1king
10 Apr 2013 23:03
#581725
Well I have it all tore down and have started getting some parts cleaned up. Lots od polishing,painting and so forth needed.
Fork legs and swinger polished.
Attachment DSCN2477.JPG not found
Got the frame stripped down. Found out I can't or am scared to lift one of these moto
Attachment DSCN2483.JPG not found
rs by myself anymore!
  • bluezbike
  • bluezbike's Avatar
11 Apr 2013 02:54
#581770
You are correct to be wary of these motors, they are reeeeeally heavy....but check Arnold's 2.0 build, he tells how he put the motor on its side and then lowered the frame onto the motor. He had just painted the frame too and not a scratch on it, a few others have also done this. Sounds like a very good and safe idea. :) Liking the build so far man.
79 KZ 1000 LTD
  • kzz1king
11 Apr 2013 12:14
#581801
bluezbike wrote: You are correct to be wary of these motors, they are reeeeeally heavy....but check Arnold's 2.0 build, he tells how he put the motor on its side and then lowered the frame onto the motor. He had just painted the frame too and not a scratch on it, a few others have also done this. Sounds like a very good and safe idea. :) Liking the build so far man.
I have done the motors both ways and much prefer the lay down method but it only works if you are removing front and rear ends I think. Actually thats how I got the motor out but then I had to get it on my little cart :( USED to be able to lift them :huh: Maybe I am just smarter now!
Wayne
  • kzz1king
17 Apr 2013 22:40
#582892
I have been looking for some different pegs to put on my stock brackets. The main reason I wanted narrower pegs is so I can still use my kick starter with the ghetto rear sets. They did not require much modification but I may cut the mount and twist the peg closer to the proper place.
Wayne
Attachment DSCN2494.JPG not found
Attachment DSCN2495.JPG not found
  • kzz1king
20 Apr 2013 18:35
#583331
Got a little bike time in today. Too much snow and mud to ride. I got the ends caped where I hacked the sub frame off. No pipe bender so I copied this idea that I seen done on the forum. Worked out okay. Some grinfing and filling yet to do.
Wayne
Attachment DSCN2497.JPG not found
Attachment DSCN2498.JPG not found
Attachment DSCN2499.JPG not found
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
23 Apr 2013 11:30
#583683
that is the reason i like metal so much.
the grinder takes away.
and,
the welder replaces.
a lil time and patience and no one will be able to tell that it didn't come from the factory that way.
  • kzz1king
18 May 2013 20:10
#588098
Have not had much time lately but did get the frame pretty much done. Figure I better post something before it ends up in a DOA thread :woohoo: Need to finish cleaning up the motor so I can free up some space to rebuild fork,calipers and what not.
Attachment DSCN2554.JPG not found
Wayne
  • ramtough_63
  • ramtough_63's Avatar
19 May 2013 22:24
#588244
awesome work
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
  • kzz1king
19 May 2013 23:04
#588253
ramtough_63 wrote: awesome work
Thanks Ram, I appreciate it.
Wayne
  • kzz1king
29 May 2013 18:58
#589786
Got a little shop time in today.
Wayne
Attachment DSCN2621.JPG not found
Attachment DSCN2622.JPG not found
