Search Results (Searched for: Acewell)
Replied by Bowman on topic Acewell Speedometers
31 Jan 2016 04:50
I'm going to switch it over to the right and put a cupholder for my beer on the left.
Replied by SWest on topic Acewell Speedometers
31 Jan 2016 04:41
Seems to be missing something on the right side. :dry:
31 Jan 2016 04:35
I got one for my 750 Twin but in the black plastic case. Looks good (for the look I'm going for) and weighs nothing.
I haven't got the bike running yet so can't say how it works on the road. I did wire it up to the harness and power it up and programmed all its little functions. Documentation is wonky in places but if I figured it out then just about anybody with opposable thumbs ought to be alright. The display is small but quite readable, remains to be seen if its still readable at 7000 rpm of course.
Attachment P1010984-2.jpg not found
30 Jan 2016 17:53
Nice unit.
Acewell Speedometers was created by kaw-a-holic
30 Jan 2016 17:40
Anyone have experience with these all in one speedometers? I am looking at this unit:
www.dimecitycycles.com/brushed-aluminum-...eter-tachometer.html
My Trail Tech Vapor works great but it won't read the signal from my new ignition correctly. One of the cool things about the Acewell is that it has a speedo adapter that plugs right into my GSXR forks. Secondly, it will work with my ignition.
www.dimecitycycles.com/vintage-cafe-race...zuki-drz-ace-s6.html
Feedback welcome as always.
Replied by 650mod on topic Bobbers and Street fighters
18 Jan 2016 04:02
rstnick wrote:650mod wrote: Here's my contribution to this thread. It took me around 2 years to finish everything up on the fighter build part, just chipping away at it whenever I could. She started out as a '78 C2 KZ 650 that needed lots of engine work and some paint to bring it back to life. I started out on the engine, and put a Wiseco 720 big bore kit in it. Threw on a 4-1 exhaust from a 2002 Kawi Z750, and a stage 3 Dyna jet carb kit with pods. Repainted everything, and rode it for a season. Decided that the suspension and brakes needed work, so apart she came. The front end is off a 2001 Buell Lightning X1. We had to lathe/cut/weld the steering stem down to fit the KZ steering tube. The rear end is off a '99 Ninja 600 with the wheel from a '99 Ninja 900. With the suspension swap, the bike is dropped 3.5 inches and stretched 3 inches. I wanted to keep everything looking as stock as possible, so this took some good head scratching and planning out. We made up a custom rear shock mount that allowed me to leave the battery box in it's location. Foot rests are off a '99 Ninja 750. And the speedo is an Acewell unit, nice and compact. She still needs a little work, but I rode her all last season, and what a difference everything made. She weighs about 30lbs less with all the aluminum parts on it now, and handles like a dream. My next step is to make up a custom exhaust as this one drags on the ground in some corners and bumps. I also need to shorten up the headlight ears a bit.
But this is my take on a streetfighter. I tried to leave as much of the KZ look as I could, while adding as much new gear as I could.
Attachment kz1.jpg not found
Looks great!
Thanks Rob!
Replied by rstnick on topic Bobbers and Street fighters
17 Jan 2016 14:56
Looks great!
Replied by martin_csr on topic 1987 KZ1000P Crashed the speed/tach cluster
09 Jan 2016 02:23
chinese junk ripoff? ... Acewell copy?
ps: I did not see that Acewell was mentioned above. doh.
Replied by TexasKZ on topic 1987 KZ1000P Crashed the speed/tach cluster
04 Jan 2016 12:13 - 04 Jan 2016 12:18
Acewell and Moto Gadget both make interesting aftermarket guages.
For legal advice, check with your local DMV, as the laws can be quit different from one place to another.
I think that most any guage set from a post-1981 Kawasaki 1000 or 1100 should work. One thing to watch for is whether the speedometer is cable drivin or electronic. The easiest choice is to use whatever drive system your bike already has. You may also have to do a little fabrication to get a different mounting bracket to work on your bike.
Displaying 41 - 50 out of 519 results.
