Search Results (Searched for: Acewell)
Replied by larrycavan on topic Changing out my Gauges for somthing Newer !!
12 Feb 2010 17:03
Awesome guage!
I have an Acewell like OMR's. The only thing I wish is it was about 50% larger.
Replied by Old Man Rock on topic Corrected Spark Plug "BASE" Reading
06 Feb 2010 13:44 - 06 Feb 2010 13:47Replied by Old Man Rock on topic Changing out my Gauges for somthing Newer !!
10 Jan 2010 03:01 - 10 Jan 2010 03:04
If interested...ACEWELL Speedo's....
www.electrosport.com/street/speedometers.php
Speed sensing several ways... but most are inductive or magnetic pick ups...
If you research into OEM specs on newer bikes, they pick up or count cc sprocket tooth counts in the tranny gear box areas.
Easiest, magnet on the front rotor...
Tach, conductor soldered into a coil primary feed...
Speed... Provided rotor magnet and fab up a mounting bracket...
OMR
OMR
Replied by kano on topic speedometer with r1 front end?
14 Dec 2009 19:59Resistor plug caps? was created by sbulla
14 Nov 2009 09:19
I was looking through my Clymer manual and noticed it stated that "'77 and later models use resistor plug caps". The PO of my bike has replaced the stock coils with Dyna greys and the wires are yellow (Accel?) 7mm copper core non-resistor caps. The stock IC igniter and sensors are still in use but the ballast resistor is removed and I installed the WG mod.
Should I be using the resistor cap wires? I recently replaced my plugs with BR8ES (resistor) plugs to cut down on the fluctuation of my Acewell tach. Does this negate the use of resistor caps?
There's no major problem with the bike, I'm just double checking things while working on a small stumble off idle I experience and thought I might replace the plug wires as they look quite worn in places.
Sonny
Sonny
Replied by Old Man Rock on topic kz1000p stock to cruise sprocket
07 Nov 2009 05:43
Obviously this got me thinking me more about this... :blush: Oh well, deal with it.... :laugh: :laugh: :laugh:
As can be reviewed below for MY SETUP....
@ 15/35 OEM sprockets, 2.33 ratio @ 110.6mph @ 8Krpm....
@ Present setup 15/37 OEM sprockets, 2.46 ratio @ 104.7mph @ 8Krpm....
@ 14/33 OEM sprockets, 2.35 ratio @ 109.5mph @ 8Krpm....
So by going up 2 teeth on the rear, leaving front alone due to my ZX6 pivot tube size I gained significantly in accelerations. Yes, lost top end speed which I didn't care about in my engine build... Remember, I went with low/mid range performance in my camshaft selection...
Considering the above mentioned, 1015cc kit, Keihin CR29mm carbs and tire/rim sizes, at 65mph my tach displays 4500rpm. The Acewell 2802 tach has a +/- 300rpm tolerance... Then throw in timing advance/retarded etc... So fairly close to the calculated speed/rpm values....
2.46 - 2.33 = .13 difference!
2.35 - 2.33 = .02 difference! :blush:
Now if you would have went one down on the front and 2 up on the rear (14/35 combo) ...
@ 14/35 OEM sprockets, 2.50 ratio @ 103.2mph @ 8Krpm....
2.50 - 2.33 = .17 difference! :woohoo:
Just for shits&giggles....
@ 14/37 OEM sprockets, 2.64 ratio @ 97.7mph @ 8Krpm....
2.64 - 2.33 = .31 difference! :woohoo:
Good luck on keeping this front end on the ground!
In any case, seems you got the other issues resolved from last week and are back on the road... Sweet!
OMR
OMR
Replied by timebomb33 on topic kz650/636 Hybrid
05 Nov 2009 17:15
OMR has the acewell and he did a whole writeup on it in the projects section last time i talked to him about it he was happy with it.
Replied by thompsonmx100 on topic kz650/636 Hybrid
05 Nov 2009 16:45
Yes sir doing fine. The acewell guage that Kano posted has all kinds of adapters I'm kinda leaining in that direction as they have an adapter that will run off the speedo drive as on my front end the speedo drive doubles as a wheel spacer. The guage is still electronic but get converted. Kinda cool. Have you made any more progress with your bike?
Replied by timebomb33 on topic What brand of Tach is this?
26 Oct 2009 21:21
i thought it was an acewell so i went to their site to check it out and the website completely infected my computor freakin chinese crap it took me hours to get this dam thing to work again don't go on there web site it's freakin nasty with what it will do.
Replied by OnkelB on topic Dyna S rpm gauge not working
16 Oct 2009 13:53
Dave, upon closer inspection you're right, the Acewell instructions actually shows both methods, the wrap method is shown on the front page while the direct method is shown in the diagram. Seems I missed the fine print...
Bully, no problem, only happy to help.
Displaying 321 - 330 out of 519 results.
