Flash Rust post Evaporust KZ Tank: PICS 28 Mar 2023 17:02 #882135
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Thank you received: 1287
Rinse the tank with water then spray a bunch of WD 40 into the tank. The WD 40 will penetrate the water and coat the tank. Drain the tank upside down and let it dry out. I've done it dozens of times and never had any flash rust. Later, after the tank has dried out a quick rinse with gasoline and you're ready to go.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Flash Rust post Evaporust KZ Tank: PICS 28 Mar 2023 17:50 #882136
  • DanMadBoy
  • DanMadBoy's Avatar Topic Author
  • User is blocked
  • Thank you received: 14
Bill
Thanks Bill.
Im thinking Evaporust, wash out with fuel, then wd-40 then more fuel? Sound like a plan?
Flash Rust post Evaporust KZ Tank: PICS 28 Mar 2023 19:17 #882140
  • KZQ
  • KZQ's Avatar
  • Administrator
I've never used Evaporust and would not discount the experiences of those who have used it. I did read earlier, in this thread, that you follow Evaporust with a water rinse.
I would follow the water rinse with WD 40 as it will penetrate through the water and cling to the metal. Before I used WD 40 flash rusting was always a problem. Since I've moved to WD 40 I've never had any flash rusting.
Diesel fuel may also work to separate the water from the steel.
I strongly suspect that gasoline in a water wet tank will result in water becoming trapped in any crevasses or seams.
My preference is Muriatic Acid | Agitation | Water Rinse | WD 40 | Gasoline rinse.
Use care when using muriatic acid. I use an old rain coat, plastic gloves and a face shield.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: by KZQ.
Flash Rust post Evaporust KZ Tank: PICS 28 Mar 2023 19:18 #882141
  • DanMadBoy
  • User is blocked
Bill
Thanks for reminding me what is in the thread. I forgot. Now I will be following the plan you outlined! Thanks so much
Last edit: by KZQ.
Flash Rust post Evaporust KZ Tank: PICS 28 Mar 2023 19:42 #882142
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2716
Muratic acid is super strong stuff.  Nasty, really.  I wouldn't use it for your first try on derusting.
Flash Rust post Evaporust KZ Tank: PICS 29 Mar 2023 17:40 #882164
  • DanMadBoy
  • User is blocked
Bill
Took the bike out for a spin and then took off the tank. Currently soaking in Evaporust. I only bought a gallon and am rotating the tank ever 45 min.
From earlier today:
