  • Page:
  • 1
1991 zr750c1 handle bars and forks question 02 Jan 2024 06:43 #893427
  • Robby2894
  • Robby2894's Avatar Topic Author
  • Thank you received: 7
Can anybody tell me what these clip-on handlebars and forks might be off of? Obviously they arent stock, so any ideas on what bikes forks wouldve been compatible to fit? It has Dual disk brakes, and I will post a reply with the wheel size later when I can go look at it.
1991 zr750c1 handle bars and forks question 02 Jan 2024 18:04 #893459
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2081
No pictures. Be sure to click Insert All before submitting the post.
1991 zr750c1 handle bars and forks question 02 Jan 2024 18:06 #893460
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2688
Last edit: by Nessism.
1991 zr750c1 handle bars and forks question 02 Jan 2024 20:01 #893466
  • Robby2894
Sorry. Thanks haha
1991 zr750c1 handle bars and forks question 02 Jan 2024 20:46 #893469
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 262
Forks and triple tees look to be stock ZR750, stock handle bar was mounted in blocks bolted to top of tree.  Not a clue what the clip ons are from.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
The following user(s) said Thank You: Robby2894
1991 zr750c1 handle bars and forks question 03 Jan 2024 05:17 #893481
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1630
From an EB item searching the part number, that seems to be correct. has a good pic. looks the same.
ZR750-C1 Upper triple: 44039-1209.
EB item #160632077314
Last edit: by martin_csr.
  • Page:
  • 1
