  • Page:
  • 1
Spoked wheels without tubes 25 Oct 2023 18:31 #890965
  • ckahleer
  • ckahleer's Avatar Topic Author
  • Thank you received: 139
I like the looks of spoked rims, but don't want to use inner tubes. A 450 Rebel I had a few years ago had tubeless spoked rims. Do any other bikes have this?
94 KE100
81 CM200t
82 KZ305
85 VT 500c
85 VF1100c
Spoked wheels without tubes 25 Oct 2023 19:57 #890970
  • TexasKZ
  • TexasKZ's Avatar
  • Away
  • Thank you received: 2081
BMW
Spoked wheels without tubes 27 Oct 2023 18:53 #891031
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
Spoked wheels without tubes 27 Oct 2023 20:36 #891032
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 262
Most spoked wheels don't have bead retention ribs (your Rebel wheels had them, and I'm sure BMW wheels do also) to keep the beads from losing their seal in the case of low pressure.  I don't think it would be safe to run a tire without a tube on a rim that wasn't designed for it.  Manufacturers wouldn't have made tubeless rims with ribs if there wasn't a need for them.  All automotive wheels designed for tubeless tires also have them.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
The following user(s) said Thank You: slmjim+Z1BEBE
Last edit: by sf4t7.
Spoked wheels without tubes 28 Oct 2023 05:50 #891033
  • TexasKZ
  • TexasKZ's Avatar
  • Away
The BMW makes some spoked wheels that are designed to be tubeless. The Outex conversion seems to be pretty popular with the BMW folk who have the older design spoked wheels.
Last edit: by TexasKZ.
  • Page:
  • 1
