  • Page:
  • 1
Brake Caliper Rebuild Kit Installation 06 Nov 2014 10:30 #653047
  • 79MKII
  • 79MKII's Avatar Topic Author
  • Love Them Kaws!
  • Thank you received: 43
Hello All,
Just having a brain cramp and the manual isn't much help. I can't remember how the caliper bracket dust seals were mounted....should they go all of the way down on both sides?? Please see photo below. Thanks
The Kaw List:
Brake Caliper Rebuild Kit Installation 06 Nov 2014 10:35 #653048
  • 79MKII
  • Love Them Kaws!
Kits and parts diagrams call for same boots for all four locations. The RH side boots are not seated as shown above....not sure if that being loose at the end will matter? it seems that the face of the boot might be better placed flat against the face of the spacer as it is on the LH side....thoughts?
The Kaw List:
Last edit: by 79MKII.
Brake Caliper Rebuild Kit Installation 06 Nov 2014 15:48 #653091
  • spdygon
  • spdygon's Avatar
  • Thank you received: 117
Don't mean to high jack you post but I was about to ask the same question.
Have all this rubber pieces left...calipers only had the piston seal and dust boot.
The bolt caps would not stay in place.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
Brake Caliper Rebuild Kit Installation 06 Nov 2014 15:51 #653092
  • spdygon
  • spdygon's Avatar
When installing the bolt...as I would put pressure the cap would come off the bracket.
So I left them off.
1974 Z1 900 project
Last edit: by spdygon.
Brake Caliper Rebuild Kit Installation 06 Nov 2014 19:39 #653107
  • spdygon
  • spdygon's Avatar
79mk2.......
just finish my kit install....yes that how they go. did not know the o-rings went inside the bracket hole into a ring channel.
took a while to bleed to brake lines....suck 1.5hours
1974 Z1 900 project
Brake Caliper Rebuild Kit Installation 07 Nov 2014 07:33 #653137
  • 79MKII
  • Love Them Kaws!
spdygon wrote: 79mk2.......
I had a hard time remembering where the o-rings went too! It's been a while since I've done a total rebuild. I'm not looking forward to bleeding the system....that part always sucks.
The Kaw List:
Brake Caliper Rebuild Kit Installation 20 Feb 2024 20:30 #895474
  • Naxos
  • Naxos's Avatar
Any tips on getting this bracket on the caliper with the dust seals seated properly? I can’t seem to get them in without them coming off the bracket.
Brake Caliper Rebuild Kit Installation 25 Feb 2024 16:47 #895592
  • rstnick
  • rstnick's Avatar
  • Thank you received: 374
Lubrication!
Some grease to hold the boots on, and slide into the caliper.
I used a wheel bearing grease, on the bolts/sliders.
Carefully slide the bolts in, making sure the boots don't get distorted.
I recall the 650's to be tricky, but managed.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: by rstnick.
  • Page:
  • 1
