  • Page:
  • 1
Hi-beam and Lamp warning indicator lamps flickers after fuse box replacement 21 Oct 2023 02:16 #890728
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
  • Thank you received: 34
Brand new Sylvania installed and brand new battery
Simple fuse box replacement, right?
I did only one fuse at a time for the sake of keeping it simple and saving myself "the mysterious wire" headache lol
All seemed to go smooth, when completed. It fired up, but now my headlamp, 'high-beam', and 'lamp' indicator lamps flicker, ..flickering gets worse with any throttle given.
Any of you have any idea what I could've possibly done to cause this symptom?
1982 KZ1100D1
Hi-beam and Lamp warning indicator lamps flickers after fuse box replacement 21 Oct 2023 03:43 #890730
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 675
Loose connection, increase in revs increases the vibration and connection make/break.
Could be either a terminal connection or if still on glass fuses a dodgy connection in the fuse. Glass fuses are Chinese made these days and shit quality.
Z1000J2 somewhat modified!
The following user(s) said Thank You: Gdailey2112, Wookie58
Last edit: by Warren3200gt.
Hi-beam and Lamp warning indicator lamps flickers after fuse box replacement 21 Oct 2023 06:51 #890736
  • Gdailey2112
  • 82 KZ1100D1
Went out this morning and checked the clamping ability on the three headlamp connectors and found one that was downright gapped out. Problem solved and once again you Warren had the answer. Thanks man!
1982 KZ1100D1
The following user(s) said Thank You: Warren3200gt
  • Page:
  • 1
