  • Page:
  • 1
Spark Plug Defect? 18 Oct 2023 10:31 #890608
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Thank you received: 636
The ceramic post on one spark plug easily spins around on the body.  There are no other visible irregularities.
Should the spark plug be used, or rejected as defective?
Short video below:
photos.app.goo.gl/vtzhU9eKyA96jLKP9
1982 KZ1100-A2
Last edit: by daveo.
Spark Plug Defect? 18 Oct 2023 11:25 #890610
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2706
Looks bad to me.  I'm no expert, though.
One thing, those plugs are resistor type, so be sure that you are not using resistor plug caps or resistor wires when running them.
Spark Plug Defect? 18 Oct 2023 11:39 #890613
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1869
I suspect you will loose compression through there and it may even blow the centre out if you get excited, should be "crimped" tight
Spark Plug Defect? 18 Oct 2023 11:39 #890614
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 262
In 45 years, never seen the ceramic spin like that.  Throw it away.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Spark Plug Defect? 18 Oct 2023 13:34 #890626
  • Nerdy
  • Nerdy's Avatar
  • Away
  • Thank you received: 387
I would ask the manufacturer: they should be able to tell you for sure.
If it's wrong/defective, they might also want to investigate if it's a one-off or if there was a bad batch.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
The following user(s) said Thank You: slmjim+Z1BEBE, daveo
Spark Plug Defect? 18 Oct 2023 14:33 #890628
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
  • Thank you received: 312
Could also be a counterfeit plug.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
The following user(s) said Thank You: slmjim+Z1BEBE, daveo, Wookie58
Spark Plug Defect? 18 Oct 2023 16:02 #890634
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2088
I would want my money back.
  • Page:
  • 1
