  • Page:
  • 1
  • 2
BS34 and BS36?? 06 Mar 2024 16:53 #896063
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
  • Thank you received: 34
Not sure what the carb on the left is, the hat is larger, the pilot mixture jets are a smidge larger in diameter. and the fuel connector tubes/tee are of a larger diameter. Please identify what the carb on left is, it has 49400 Fy29 on the side. The one on the right is CV BS34, I'm quite certain of that. Much thanks!
1982 KZ1100D1
Last edit: by Wookie58.
BS34 and BS36?? 06 Mar 2024 17:45 #896069
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 384
I do not know what it is. Some more data might help. Will say there are clones being made and sold. Will say the IDs stamped on the Mikuni carbs stock on several GS bikes begin with a 4. i have seen a list with has 4900 listed as stock on early 80's GS1100 as BS34ss carbs. Am I saying that is what they are NO
As I said I do not know what it is. Others here may well know.
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
BS34 and BS36?? 07 Mar 2024 00:32 #896079
  • Gdailey2112
  • 82 KZ1100D1
Thanks for your response! Really there is no more data is on there, but all I wanna know is if it's a BS36, 34, or 38. The hats are a bit bigger, my BS34 hats are not compatible, and they are spaced for a Suzuki.or Yamaha
1982 KZ1100D1
BS34 and BS36?? 07 Mar 2024 04:02 #896087
  • asphalt900
  • asphalt900's Avatar
  • Thank you received: 167
Should be a Suzuki GS. That 5-digit number is the last of the 10 provided by Suzuki. Search thru partzilla starting at 1980 models.
BS34 and BS36?? 07 Mar 2024 04:16 #896090
  • asphalt900
Think Suzuki 1982 GS1100G, number corresponds.
BS34 and BS36?? 07 Mar 2024 06:19 #896098
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2707
I can't see the picture.  All I see is a tiny little thumbnail.
Regarding Suzuki carbs, the 1000 and 1100 bikes used BS34's.  There are some slight differences between shaft and chain bikes.  BS36's were used on the GS1150 model.
BS34 and BS36?? 07 Mar 2024 06:28 #896099
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1892
I have edited the pic
The following user(s) said Thank You: Gdailey2112
BS34 and BS36?? 07 Mar 2024 07:57 #896111
  • gd4now
  • gd4now's Avatar
To learn it size measure the throat of the carb where the slide meets it.  It should give you the size.
1977 KZ650 B1
This is my Z
BS34 and BS36?? 07 Mar 2024 10:09 #896114
  • asphalt900
Let's make this easy...with photo differences. Like mentioned, buying on ebay ya gotta know certain perimeters of what is original or touted as such. So.. note the differences between the Suzuki and Kawasaki versions. The Suzuki casting boss's near the pilot fuel screws were not drilled and have a brass fitting barb, only #2, for petcock vacuum. Why, because they had allen screws in the intake port of the head  to access sync in the casting. Whereas the Kawaski were drilled and have brass barbs on all of them for sync procedure. Also noteworthy, Yamaha used a similar Mikuni design, also printed on the side but "another bird of various design intents". Second denote of recognition, Suzuki, had a lip of larger milling in the intale side of venturi, see pic.
BS34 and BS36?? 07 Mar 2024 11:48 #896115
  • asphalt900
And some other differences while on the tangent of dissimilar item bits between the era of when these type Mikuni carbs reigned supreme during the early 80's. Suzuki choke plungers never used the sealing bellows, just simple rubber sealers. Easy way to differentiate, Look at the photo differences between the Kawasaki (bellow sealing lands x2) on the plunger compared to the singular land for the Suzuki. And many more tidbits but i won't bore you fella's with that.
BS34 and BS36?? 07 Mar 2024 14:59 #896127
  • gd4now
  • gd4now's Avatar
Thank you for sharing the changes between the carbs as you have noted. Interesting how different things can be noted if looking closely at the items from each maker.
1977 KZ650 B1
This is my Z
BS34 and BS36?? 08 Mar 2024 21:12 #896196
  • Gdailey2112
  • 82 KZ1100D1
Thank you! Not sure what I did there
Wookie58 post=896099 userid=60568
1982 KZ1100D1
  • Page:
  • 1
  • 2
