  • Page:
  • 1
Rear Stand 29 May 2010 09:06 #371858
  • gte105u
  • gte105u's Avatar Topic Author
  • Thank you received: 0
I have a hydraulic car jack. Anyone have a good way of making a quick make-shift wheel stand? When I got my 550 it did not have a center stand. I plan on buying one, but need to switch the rear sprocket out ASAP to pass inspection and get it legal. No one local has a rear stand for me to buy.
1981 KZ550 A2
Rear Stand 29 May 2010 09:45 #371871
  • Old Man Rock
  • Old Man Rock's Avatar
  • Thank you received: 225
2 car jack stands, one of each swing arm tube works just fine... ;)
Lean the bike one way, stand on the lowest settings, lean back then place the other stand...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Rear Stand 29 May 2010 11:07 #371887
  • hocbj23
  • hocbj23's Avatar
  • Visitor
Paddock lift.Ebay.40 bucks.bj
Rear Stand 29 May 2010 12:22 #371894
  • Thank you received: 2098
Also several KZ550 center stands currently listed on ebay.
Good Fortune! :)
Rear Stand 29 May 2010 14:34 #371911
  • gte105u
I plan on getting a center stand from ebay, but wanted something makeshift to use today. I was going to have my chain/sprockets replaced at the dealer b/c I cannot legally ride until they do (failed state inspection because of sprockets). Dealer said it would late next week before they had time, so I wanted to do it this weekend. FWIW, the two car jacks worked like a charm once I go the hang of it. Thanks for the tip.
1981 KZ550 A2
Rear Stand 30 May 2010 23:47 #372235
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1616
You might be able to make something out o fht grab rail. I made a stand out of two of them. They are already the right distance apart to mount to the shock bolts.
home.comcast.net/~loudgpz/GPZweb/GPZswgarmStand.html
We used this one on my buddies KZ650. The shock bolts lined up the same as the 550's.
  • Page:
  • 1
