  • Page:
  • 1
  • 2
Does a cylinder head with dropped valve have any value? 28 Jan 2024 08:32 #894519
  • PoMoFleet
  • PoMoFleet's Avatar Topic Author
  • Thank you received: 1
This cylinder head looks kind of bad to me but upon inspection it doesn’t have any broken fins. It does have missing screws and one of the valve ports look bad. can it be salvaged or is it ready for salvage? Appreciate y’alls expertise. Thoughts?
Does a cylinder head with dropped valve have any value? 28 Jan 2024 08:55 #894521
  • Wookie58
  • Wookie58's Avatar
  • Online
  • Moderator
  • Thank you received: 1932
That one is "marginal" at best, all the damage would need smoothing out to avoid "hotspots" and "pre-ignition" removing that much material would lower the compression on that cylinder. the valve seat would need replacing and probably the guide, it's repairable but would be expensive to do correctly
Edit: the ports look a mess also, hard to tell from the pics how bad
The following user(s) said Thank You: PoMoFleet
Last edit: by Wookie58.
Does a cylinder head with dropped valve have any value? 28 Jan 2024 09:11 #894522
  • PoMoFleet
Not sure it gets better with the pics. Thank you. If anyone in the community wants to practice on it and wants to make a gentle-person’s (nominal) offer + pay for shipping (heavy) I’ll send it your way. Just holler.
Otherwise it’ll be shelf art.
Does a cylinder head with dropped valve have any value? 28 Jan 2024 09:11 #894523
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 519
30 cents a pound for aluminum at a scrap yard! Don't waste any time on that! I've scrapped better ones
Does a cylinder head with dropped valve have any value? 28 Jan 2024 10:41 #894534
  • zed1015
  • zed1015's Avatar
  • Away
  • Thank you received: 1489
Easily fixable.
Don't scrap it..
Does a cylinder head with dropped valve have any value? 28 Jan 2024 11:12 #894536
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2720
Scrap metal.  Anything can be fixed, but why?  Find a better head.  They aren't that expensive.
The following user(s) said Thank You: SWest, PoMoFleet
Does a cylinder head with dropped valve have any value? 28 Jan 2024 11:55 #894543
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2649
Depends on what it is. My KZ 1000 junk head was bad but not that bad. Took some doing and light porting then it turned out GREAT. I wouldn't even try with that one.
Does a cylinder head with dropped valve have any value? 28 Jan 2024 12:59 #894546
  • willemZ900
  • willemZ900's Avatar
  • Z1B 4 ever
  • Thank you received: 53
Also no cam caps, nice cylinder to "play" but don't put any money in it
Does a cylinder head with dropped valve have any value? 28 Jan 2024 13:52 #894551
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2100
If you have the cam cap that came with that head, a proper shop with the right equipment and experience can fix it.
Does a cylinder head with dropped valve have any value? 28 Jan 2024 20:02 #894564
  • Injected
  • Injected's Avatar
  • Thank you received: 459
You have to remember you can't deck (skim) a 650 head very much unlike a 900 head, that issue will play into that combustion chamber repair.
Last edit: by Injected. Reason: sp
Does a cylinder head with dropped valve have any value? 28 Jan 2024 20:57 #894565
  • SWest
  • SWest's Avatar
  • 10 22 2014
Looks like a KZ 1000 head so it might be worth fixing.
Does a cylinder head with dropped valve have any value? 29 Jan 2024 07:53 #894586
  • Injected
  • Injected's Avatar
My bad, did not see the bearing shells...
  • Page:
  • 1
  • 2
