  • Page:
  • 1
Broken head overhanging threads 27 Jan 2024 11:55 #894492
  • Buffalo515
  • Buffalo515's Avatar Topic Author
  • Thank you received: 5
Picked up an 84’ gpz 550 for a good deal. Bike sat for many many years. Upon diss assembly I noticed this broken off piece that secured the valve cover.
Wondering if anyone knows a good way to repair. Is welding a piece then retapping the only way?
I have a spare engine out of an 85’ but would like to salvage this if possible. Thanks.
Travis
Maryland
1981 GPZ 550 -gone
1984 GPZ 550
1985 GPZ 550
Broken head overhanging threads 27 Jan 2024 12:41 #894494
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1925
It would need welding and re-tapping if you want it to hold pressure on the gasket. I suspect anything less will result in incurable oil leaks
Broken head overhanging threads 27 Jan 2024 16:14 #894503
  • Buffalo515
That’s what I’m figuring. Just wanted to see if anybody had any creative ideas.
Travis
Maryland
1981 GPZ 550 -gone
1984 GPZ 550
1985 GPZ 550
Broken head overhanging threads 28 Jan 2024 07:18 #894517
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 387
I agree the correct way to fix that is with a weld. bore and tap as Wookie suggested. I can not tell from the pics but you might be able to build a clamp (threaded rod and nuts etc) to put some pressure on the cover/gasket. But it would only be a temp solution at best.
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
Broken head overhanging threads 29 Jan 2024 08:34 #894588
  • Buffalo515
I appreciate your input. Time to go find someone with a TIG!
Travis
Maryland
1981 GPZ 550 -gone
1984 GPZ 550
1985 GPZ 550
  • Page:
  • 1
