Z550 Cylinders, pistons and head on Z400J bottom end? 02 Aug 2023 16:14 #887875
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1480
Thanks for the info! got a question, I can only track down 3 oversized pistons. would it be possible to use 3 over size and 1 standard ? or would this unbalance everything ?
It's been done before as a last resort but not really recommended although i have had engines in that have had similar done ( 3 stock and 1 OS ) and were running just fine.
The OS piston would need weight matching to the others at the very least.
Z550 Cylinders, pistons and head on Z400J bottom end? 02 Aug 2023 16:17 #887876
  • MrGMoto
  • MrGMoto's Avatar Topic Author
  • Thank you received: 0
okay, thanks, I can get 3 O/S but can't find a fourth so was thinking of doing the 3 O/S and 1 standard  or 2 standard and 2 O/S. :/
Z550 Cylinders, pistons and head on Z400J bottom end? 02 Aug 2023 16:23 #887877
  • zed1015
  • zed1015's Avatar
What model pistons do you mean , 400,500,550 ? and why can't you use 4 std if you can use 2 .
Z550 Cylinders, pistons and head on Z400J bottom end? 04 Aug 2023 01:34 #887925
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1885
It may be worth searching some of the Japanese websites for pistons - due to taxation and insurance brackets 400's where hugely popular in Japan (hence the flood of 400 imports to the UK in the 80's - GSXR's, CBR's, ZXR's etc) "cruzinimage" don't list them but probably worth an email?
Last edit: by Wookie58.
Z550 Cylinders, pistons and head on Z400J bottom end? 04 Aug 2023 16:12 #887952
  • Injected
  • Injected's Avatar
  • Thank you received: 453
If your going to all this trouble and can afford the cost used good forged pistons = Wiseco 615cc kit
You get a nice bump in compression and some tougher pistons.
Last edit: by Injected. Reason: sp
Z550 Cylinders, pistons and head on Z400J bottom end? 15 Aug 2023 12:54 #888295
  • Sixten
  • Sixten's Avatar
  • Thank you received: 3
Instead of starting a new thread I can ask here maybe?
Would it be possible to put a 400 crank in a GPZ550 engine to make it 500cc?
Kr Sixten
Z550 Cylinders, pistons and head on Z400J bottom end? 15 Aug 2023 13:53 #888298
  • zed1015
  • zed1015's Avatar
Kr Sixten
Yes! but you will still need to shorten the 550 block and use a shorter camchain etc.
Last edit: by zed1015.
Z550 Cylinders, pistons and head on Z400J bottom end? 16 Aug 2023 04:22 #888316
  • Sixten
  • Sixten's Avatar
The machining is no problem.
It should be possible to use the 400 cam chain I guess?
Would make a cheap and hopefully powerful and reliable 500cc race engine.
I found this engine en Europe.
www.motorparts-online.com/en/kawasaki/gp...994/engine/201523834
Says it’s 1989-1994 but it looks the same to me. Does anyone know if it’s the same?
Last edit: by Sixten.
Z550 Cylinders, pistons and head on Z400J bottom end? 16 Aug 2023 06:57 #888322
  • zed1015
  • zed1015's Avatar
That will do the job for the bottom end.
They all use a hyvo camchain so which ever combo of parts is used the 400 chain will be needed.
Z550 Cylinders, pistons and head on Z400J bottom end? 16 Aug 2023 07:52 #888324
  • Sixten
  • Sixten's Avatar
Thanks for all the advice.
Maybe this can be a winter project for next season.
Z550 Cylinders, pistons and head on Z400J bottom end? 31 Aug 2023 07:20 #888884
  • Sixten
  • Sixten's Avatar
Hi again,
I found a 400 engine. Now I’m looking for a GPZ550 motor to donate pistons, cylinders and head for the 400.
What engine numbers would be the most powerful GPZ550 engine?
I remember reading somewhere earlier that the 84-85 engine had the best pistons/cams/head but I can’t find that now.
Z550 Cylinders, pistons and head on Z400J bottom end? 07 Sep 2023 13:15 #889145
  • Sixten
  • Sixten's Avatar
I found that engines starting with ZX550A have the best pistons. Unfortunatly not sold in Sweden. But I found a KZ550D engine that I believe is second best piston and cylinder donor
