And finally, Wookie's 82 begins ! 09 Mar 2024 16:48 #896232
  • Wookie58
  • Wookie58's Avatar Topic Author
  • Moderator
  • Thank you received: 1878
Been back on it today wrapping up the hand controls, I hit a small bump in the road in that the "narrow" bars I bought were too short for the furniture to clear the nosecone ( ZX6R switches and throttle, ZRX master cylinders) so I had two choices, replace or extend ? If I had replaced I would still need to have wheighted them for vibration reduction. As it happened the chrome bars I removed were weighted already so I cut a pair of extensions and welded them in   I have also turned a pair of bar end finishers (purely aesthetic)
So finally a milestone moment today ( the wheels hit the floor for the first time in nearly two years) still lots of small jobs to do but "break down" for refurb and beautification is looming
The following user(s) said Thank You: ThatGPzGuy, daveo, Street Fighter LTD, sf4t7, calum, howardhb, Stereordinary, MLMG and 2 other people also said thanks.
And finally, Wookie's 82 begins ! 09 Mar 2024 17:00 #896234
  • MLMG
  • MLMG's Avatar
  • See you in the wind.
  • Thank you received: 35
Wookie58 is displayed on your machine.
1977 Kawasaki KZ1000 A1
Last edit: by MLMG.
And finally, Wookie's 82 begins ! 09 Mar 2024 19:00 #896236
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 262
A big day !  Congrats Guy
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
And finally, Wookie's 82 begins ! 10 Mar 2024 01:03 #896238
  • Rolf1976_KZ900
  • Rolf1976_KZ900's Avatar
  • Thank you received: 127
Looks great Wookie  much work payd off !.I like the seat toI have not read the tread thrugly ,but are the wheels from yama xjr 1300 or are they zxr ?. I assume that color is just primer ?  One option that may clear the cowling is using TT clip-ons or plase the steeringbars upsidedown ,but that will not make the ride position so comfortable.
edit i saw now its suzuki gsx wheel
Last edit: by Rolf1976_KZ900.
And finally, Wookie's 82 begins ! 10 Mar 2024 01:07 #896239
  • Quofan
  • Quofan's Avatar
  • Thank you received: 8
That's looking absolutely fantastic mate. Can't wait to see it when it's all finished and painted. What colour is it going to be?
Is there any engine work required?
And finally, Wookie's 82 begins ! 10 Mar 2024 01:44 #896240
  • Wookie58
  • Moderator
thanks pal, haven't fully decided on colour yet. The engine will need a "refresh"
The following user(s) said Thank You: Quofan
And finally, Wookie's 82 begins ! 10 Mar 2024 01:48 #896242
  • Wookie58
  • Moderator
yes Rolf the yellow paint is filler/primer. The cowling issues are resolved
And finally, Wookie's 82 begins ! 11 Mar 2024 06:35 #896279
  • howardhb
  • howardhb's Avatar
  • God, I trust
  • Thank you received: 444
Seeing that your bodywork (side-covers) blend in much the same way as the Z900RS,
I think it would look SMASHING in this livery !!!
H.
'81 GPz 550 D1 Click this link: www.kzrider.com/gallery/kz-550/1981-gpz550d1-9094#joomimg
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/forum/11-projects/617040-1981-gpz1100-b1-rst
'82 Yamaha YB100 Fizzie
The following user(s) said Thank You: Street Fighter LTD, calum, Wookie58, MLMG, Quofan
And finally, Wookie's 82 begins ! 11 Mar 2024 08:09 #896283
  • Wookie58
  • Moderator
Like it Howard, or a "variation of"
And finally, Wookie's 82 begins ! 11 Mar 2024 22:10 #896308
  • howardhb
  • howardhb's Avatar
  • God, I trust
  I call it "Kawa-sabi"... you know, green & hot !
H.
The following user(s) said Thank You: Street Fighter LTD, Wookie58
And finally, Wookie's 82 begins ! 16 Mar 2024 21:08 #896502
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 636
Someone is having dreams about ZX1100A camshafts...
1982 KZ1100-A2
Last edit: by daveo.
And finally, Wookie's 82 begins ! 17 Mar 2024 01:41 #896504
  • Wookie58
  • Moderator
There is also a "filthy rumour" that I have a 1100 uni cylinder block (74 or 75mm pistons required) and a complete Uni ignition system also
