  • Page:
  • 1
Gpz1100 1984 dfi swap to carbs 03 Feb 2024 06:12 #894775
  • Adbrad
  • Adbrad's Avatar Topic Author
  • Thank you received: 2
Hi all,
I have a gpz1100 1984 that im thinking of swapping to carbs from the fuel injection system, reason for this is the ones on the bike have been butchered by the previous owner and spares are lookong hard to come by.
Im after some advice on what carbs are best for this swap and what else needs altering to make the bike run smoothly. I understand the petcock needs moving but i was wondering what electrical modifications are needed or is it simply unplug the ecu that controls the injectors bolt on the carbs and set them up properly
Thanks!
Adam
Gpz1100 1984 dfi swap to carbs 03 Feb 2024 12:28 #894791
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1892
There are a few recent threads on this topic
Gpz1100 1984 dfi swap to carbs 07 Feb 2024 17:25 #894965
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
Welcome Adam.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Gpz1100 1984 dfi swap to carbs 07 Feb 2024 23:07 #894971
  • howardhb
  • howardhb's Avatar
  • God, I trust
  • Thank you received: 444
My "Tribute" bike has had it's EFI removed and Mikuni BS 34mm CV carbs fitted.
Electrically, it is simple,  see here:
www.kzrider.com/forum/2-engine/619814-re...th-efi-wiring#893608
Jetting the carbs will depend on what exhaust and air filters you have.
H.
'81 GPz 550 D1 Click this link: www.kzrider.com/gallery/kz-550/1981-gpz550d1-9094#joomimg
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/forum/11-projects/617040-1981-gpz1100-b1-rst
'82 Yamaha YB100 Fizzie
Gpz1100 1984 dfi swap to carbs 09 Feb 2024 02:45 #895018
  • Adbrad
Thanks for the wiring diagram, i fitted the carbs and unhooked the 4 pin connector to the Efi and removed them. I just need to know which wire i need to earth to the frame? Ive attached a pic of the wiring diagram for an 84 model
Last edit: by Street Fighter LTD.
Gpz1100 1984 dfi swap to carbs 09 Feb 2024 04:39 #895019
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1985
Adbrad
 I fixed your picture to be full size .
 Next time  click the insert all tab to complete the installation
The following user(s) said Thank You: Adbrad
Gpz1100 1984 dfi swap to carbs 09 Feb 2024 06:18 #895021
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2707
I've got a set of BS34's from either a 1000 or 1100 waiting for a rebuild.  While not cheap per se, carbs like these will hold true to the KZ heritage.  If money is no object, though, I'd get some RS34's or 36's.
Gpz1100 1984 dfi swap to carbs 09 Feb 2024 06:27 #895023
  • Wookie58
  • Wookie58's Avatar
  • Moderator
I think Howards "terminology" is confusing you, from what I can see there is no "wiring" involved. I believe Howard is referring to the mechanical mounting of the igniter to ensure sufficient heat transfer  from the igniter into the frame so the unit doesn't overheat.
The following user(s) said Thank You: howardhb, Adbrad
Gpz1100 1984 dfi swap to carbs 10 Feb 2024 00:32 #895057
  • Adbrad
Thanks for calrifying guys i tested the bike after unplugging the efi 4 pin connector and all works ok. I fitted a set of 1985 gsxr750 slabby carbs and it runs surprisingly well, obviously im gonna have to balance and rejet them if necessary, currently on 128 main jet and 20 pilot jet
  • Page:
  • 1
