Rustoleum Crystal Clear?
  • davido
  • davido's Avatar Topic Author
Re: Rustoleum Crystal Clear?
27 Dec 2016 06:52
#750773
Well,Its done.
I put the last top coat on 2 days ago and kept the heating on almost constant since then.This morning,I prepped everything and (nervously) sprayed on a first,thin tack coat of Spraymax 2K. Everything seemed ok,so I went ahead emptied both cans onto it.
First impressions,Looks good. No apparent reactions with the acrylic.No runs,minimal orange peel.Minimal dust specs.and it looks quite nice.
Its now touch dry buit very much uncured so Ill put it in the bathroom (warmest room in the house) for a few hours and have a proper look tomorrow.
Sticky fingers crossed.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • missionkz
  • missionkz's Avatar
27 Dec 2016 17:30
#750804
davido wrote: Well,Its done.
Good. it will cure better with heat.
After my final clear coat, I rotated my tank every ten to fifteen mins, with it sitting about three-four feet in front of a 750watt quartz heat lamp for about two and half hours. Then I just set a side for few days.
When hard ... get ready for some tough wet sanding... that stuff is not soft like fresh lacquer. But when done, it is great stuff and extremely resistant to fuel spills and splashes.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
28 Dec 2016 07:54
#750815
+1 to everything Nessism wrote.
Also, if you're worried about the Spraymax ruining your paint, you'll be worried every time to go to the gas station using something else.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • davido
28 Dec 2016 08:47
#750817
Ok. Pretty sure everything is cured by now but Im starting with the front mudguard just in case.(Its a solid gloss black). So I started with 1200 wet&dry then up to 2000.Thats the highest I can find.
The slight orange peel has been knocked down and all the shine has gone. I bought some (Very expensive) 'Maguires ultimate polish' (for deep reflections and high gloss. Eliminates fine swirl marks) and have been attacking it by hand.There are no instructions on the can,so I dont know if Im meant to put it on,let it dry and polish it off or keep it wet and just keep rubbing?
Anyway it looks like crap! Any ideas where Im going wrong here? I want to get this worked out before I tackle the tank and tailpiece
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • missionkz
28 Dec 2016 20:56 - 28 Dec 2016 20:57
#750850
2000 is OK but not smooth enough for a motorcycle tank.
I sand wet right up to P3000 and then use white paint polish... not swirl remover. Use that stuff later.
I used a very fine/soft grade of microfiber cloth I found at an auto parts store.
Normally not used wet but I do moisten it a little bit so it is not dead dry.
You have to polish in a small area at a time using the polishing compound and a hand rag (called a tampon) (I know) .... unless you have a hand held buffing wheel with a super soft bonnet.... then move around faster so you don't burn the clear with friction.
If you use a buffing wheel, roll off an edge.... not into an edge.
www.autozone.com/sandpaper-and-body-repa...r?filters=4294856681
Bruce
1977 KZ1000A1
Last edit: 28 Dec 2016 20:57 by missionkz.
  • Nessism
  • Nessism's Avatar
29 Dec 2016 06:01
#750858
2000 grit paper is fine. You need some "fine cutting compound" to bring out the shine. The polish is the second step.
A small DA polisher with cotton bonnet really works a treat to polish out the surface. Working by hand is pure suffrage.
  • davido
04 Jan 2017 09:06
#751365
Ok. The situation now is,Ive been working on the front mudguard and the tailpiece.Both of which Ive burned through the clearcoat with the wet and dry. Started with 1200 then 2000 then 2500 (highest I could find). There is still some slight orange peel but Im afraid to go any further and rub through more of the paint.
I bought some polishing pads ( soft foam and a fleece ) for the rotex and have attacked everything with that. It seems to come up ok (using the Maguires polish that I mentioned) I reckon the next stage to be some sort or waxing to bring out a glossier shine and give a bit more protection.
Ive touched up the 'burn throughs' with a model paint brush. Tomorrow Ill have a look and see how it is.
A big problem is seeing what Im doing as Its dark when I go to work in the morning and dark when I get home so I cant get the stuff outside to have a good look in the little daylight there is at this time of the year.Another problem is that a lot of the products that you boys are mentioning are not always possible to find (rubbing compound?? for paintwork!??Sorry sir we dont have it and no idea where you could try.What about some car shampoo? That should work and itll smell nice!!!!!!!) Plus Ive spent enough on this already,Im tired of forking out money.
Anyway,thats where things are at the minute.Ill go on with it and post some photos when Im done. (Wanting to be finished and have petrol in the tank by the weekend.)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • missionkz
04 Jan 2017 14:26
#751392
OK... you can not polish with even 3000 wet paper. It will be smooth as a baby's butt, reflect light and be satin like but totally dull.
It is the polishing steps the turns it back to glossy.
It takes time and you have to be careful to not overheat the clear with friction or it just burns right through.
It's not like bare metal polishing!!
Keep your polishing tampon or pad very very slightly damp.
Use enough polishing material to do the work but don't stay on one spot too long.
Bruce
1977 KZ1000A1
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
05 Jan 2017 08:20 - 05 Jan 2017 08:22
#751455
After applying the clear I had some slight orange peel too. IIRC, I used 1500 then 2000 wet in one direction, just to knock down the peel a bit, cleaned it off with a wet sponge then used Maguires polish on a small polisher.
Some "compund" polishes are too harsh, look for a clear coat safe polish.
This was after 2000 wetsand
polish and finally wax.
1975 Z1 900
2004 KX125
Last edit: 05 Jan 2017 08:22 by Kidkawie.
  • Nessism
  • Nessism's Avatar
05 Jan 2017 09:17 - 05 Jan 2017 09:28
#751461
Meguiar's makes a litany of different compounds, from aggressive to glaze (no grit). It's customary to use a fine cut compound right after color sanding to bring up the sheen, and then move to a "polishing" compound after that. Needless to say, it's critical to not cut through the clear. When in question just leave a little more orange peel.
www.meguiars.com/content/global/catalog/MeguiarsProCatalog.pdf
Edit: this product seems like it might work okay as a single stage. Claims to remove 1200 grit sanding scratches and polish as well. Worth a try... www.amazon.com/Meguiars-Mirror-Glaze-Ult...mpound/dp/B003LMGDHI
Last edit: 05 Jan 2017 09:28 by Nessism.
  • missionkz
05 Jan 2017 13:50 - 05 Jan 2017 13:51
#751476
I'll have to try that stuff next time....
What i used to get the gloss in my avatar was inexpensive white polish from Turtle wax called Premium Polishing Compound... LOL
Bruce
1977 KZ1000A1
Last edit: 05 Jan 2017 13:51 by missionkz.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
06 Jan 2017 04:55
#751525
This is what I used on mine, it came in a 3pc set: cleaner, polish & wax.
www.meguiarsdirect.com/product/clear-coa...e-polishing-compound
1975 Z1 900
2004 KX125
