Kick Stand Length
  • NakedFun
  • NakedFun's Avatar Topic Author
Re: Kick Stand Length
05 Feb 2016 13:41
#709597
swest wrote: Doesn't the bolt thread into the fork back and have a lock nut? The shank is thicker too? Does that mean you have to drill?
No all of that is fine. You can use your stock bolt, but instead of bottoming into the backside of the fork, you have to rely on the nut and tension on the ears.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Feb 2016 13:57
#709603
I tightened mine and am still getting use to it. The stand is tight and the bike is upright. I don't think a 2" longer one would work for me. How does it fit on yours?
  • NakedFun
05 Feb 2016 14:03
#709608
Leans like my ZRX now. Works good. And it is only about an 1.5" to 1.75" longer.....
Cory
1976 Kawasaki KZ900
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • NakedFun
05 Feb 2016 16:21
#709628
So it is subtle, but here is a frontal.
Stock KZ900 A4:
[IMG
1980 KZ1300:
[IMG
Cory
1976 Kawasaki KZ900
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Feb 2016 16:28
#709631
Is the bracket bent? I'll take a pic tomorrow when it"s light. Mine stands up, almost too much.
  • NakedFun
05 Feb 2016 17:17
#709637
The stock bracket is 3/8" thick and the half round section fits the frame tube perfectly. I am not sure it could be bent.... Again, completely different suspension, wheels and ground clearance, do not apples to apples.
If yours sit practically straight up and down, how come you stated you too wanted a longer stand?
Cory
1976 Kawasaki KZ900
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Feb 2016 17:26
#709640
Mine was leaning too much. I tightened the bolt and welded the crack again. Now it's like it was when new. The new arm might raise the back end. I may be needing one like yours if it does.
