Kick Stand Length
  • NakedFun
  • NakedFun's Avatar Topic Author
Re: Kick Stand Length
01 Feb 2016 14:58
#708935
Yep, here is hoping round two is better!
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
01 Feb 2016 15:42
#708945
Take a look at the Bulldock bikes then the Sanctuary bikes, do a google images! Bulldock, most pics you'll see a block under the stand, Sanctuary, it's photoshoped out or just about purely transparent but they do it too. Guess they fight the same thing. My suggestion, take 2, make 1 and make it look original.
Les
The following user(s) said Thank You: PLUMMEN
  • redhawk4
  • redhawk4's Avatar
01 Feb 2016 15:57 - 01 Feb 2016 16:12
#708947
The correct side stand for a KZ1000A is close to 12" from the pivot to the bottom of the foot/ground measured on the front of the leg. I went through this on my KZ1000A2 because it had a stand when I bought it which was a lot shorter than it should have been and was too short even with the 16" rear Lester Mag it came with. I managed to track down a correct replacement from an A2 and it made a big difference to the lean angle when parked and works with my replacement 18" rear, although I feel perhaps it still leans a fraction more than I'd like, but at the same time you don't want a gust of wind sending your bike over on the high side.
As already mentioned you will also be surprised how much difference a little play in the pivot makes, a shim washer or the like to tighten it on the lug is worth a lot on the leg length.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
Last edit: 01 Feb 2016 16:12 by redhawk4.
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Feb 2016 16:09
#708948
I was planning on buying one at Z1E but I welded it. It did make a big difference. I'll measure mine in the morning.
  • PLUMMEN
  • PLUMMEN's Avatar
02 Feb 2016 10:39
#709065
I think the kz stands are longer than the ltd versions,Id definately check the mount and welds on the frame also though. ;)
  • TexasKZ
  • TexasKZ's Avatar
02 Feb 2016 13:05
#709077
Seems like PMC used to sell a sexy adjustable aluminum stand, but I don't see it in the current catalogue.
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
02 Feb 2016 14:51
#709093
I took mine and milled a scrap and placed it between the bolt holes, heated it a little and put the squeeze to it and its been fine all summer.
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Feb 2016 14:51
#709258
Mine was cracked again. I ground a groove and welded it again. First I tightened the bolt. Much better. It is 9" from bolt center to bottom of foot.
  • NakedFun
05 Feb 2016 12:48
#709577
Bingo.... KZ1300 is 11" from center of boot hole to the bottom of the foot on the back side of the leg.
[IMG
Spring attachment point is the same, only difference is it takes a different bolt. The smooth shank is the same, but the threaded portion is large diameter.
Cory
1976 Kawasaki KZ900
  • tomsbadkz
  • tomsbadkz's Avatar
05 Feb 2016 13:05
#709581
What year KZ1300 did that come off of? I like that idea. tom
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Feb 2016 13:06
#709582
Doesn't the bolt thread into the fork back and have a lock nut? The shank is thicker too? Does that mean you have to drill?
  • NakedFun
05 Feb 2016 13:38
#709595
tomsbadkz wrote: What year KZ1300 did that come off of? I like that idea. tom
1980
1976 Kawasaki KZ900
