Fork Brace Question. Yeah, or Nay?
- KraZyRIDER
20 Jun 2012 01:27 - 20 Jun 2012 01:29
...several questions for those who are using one.
...did it improve the handling of your bike?
...if so, how was it noticeable?
...who was the manufacturer?
...where was it purchased?
...how much did it cost?
...thanks for the help.
...by the way, I'm looking to put one on a '79 KZ650.
Mean Green Speed Machine!
1979 KZ 650-C3 (Cafe Project)
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
Last edit: 20 Jun 2012 01:29 by KraZyRIDER.
- faffi
Re: Fork Brace Question. Yeah, or Nay?
20 Jun 2012 08:53
I've had Hondas with factory installed braces. They do seem to reduce flex, especially under hard braking with there is only one disc brake up front. They also make the fork stiffer under any load condition like hard steering or riding over bumps because they make the legs operate in pairs more rigidly, preventing one leg from moving in a different direction than the other.
So, how well do they work? The sturdier they are, the more they reduce flex. But they are then also typically heavier, increasing unsprung mass which again upset suspension and the wheel's ability to follow the road's bumps and dips.
Finally, they need to fit absolutely perfectly. If they pinch or splay the fork legs even 1/10 mm there will be noticeably increased stiction.
Telefix probably makes one of the better braces; sturdy yet lightweight
www.telefix-products.de/stabi/gabelstabi.htm
But there are others out there, like
www.gd-motobikeparts.de/Gabelstabilisator.htm
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
1980 F1 engine
B1 Points ignition
20 Jun 2012 09:04 - 20 Jun 2012 09:05
Last edit: 20 Jun 2012 09:05 by Patton.
- Motor Head
20 Jun 2012 09:47 - 20 Jun 2012 10:04
Just put one on my 82 K2 1000 LTD. Big difference in the front end of the bike. Nice and steady, much better on the gravel, it will trac the same line over a bit of un-even payment and tar snakes.
Got it from Fast from the Past, cost $100 USD. Installed in a couple of minutes. Well worth it.
www.kzrider.com/forum/5-chassis/527940-b...the-k1-k2-ltd#528050
Last edit: 20 Jun 2012 10:04 by Motor Head.
- KraZyRIDER
21 Jun 2012 02:56
...OK, some great info guys.
...the chrome options look cool, but won't fit the look of what I'm building.
...I've been looking at the Fast from the Past option. Just wondering if there are any others worth looking at.
...thanks for the info!
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
- turboguzzi
21 Jun 2012 04:41
i road race and run tarozzi's (waht FFP sells) on my two vintage bikes, it serves also as my fender mount so dont know how it is without...
that said, there are more than a few fast guys here that race without, i am talking RACE WINNING fast guys... one is a friend and says he likes better the feel without it..... so go figure.
- KraZyRIDER
21 Jun 2012 16:01turboguzzi wrote: i road race and run tarozzi's (waht FFP sells) on my two vintage bikes, it serves also as my fender mount so dont know how it is without...
...hahaha, there ya go! It only figures. Maybe if you have a "class" front to begin with, you
might not need one. But, I wouldn't exactly call a '79 KZ650 front end, a "class" front end.
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
- s1elr
- blood runs green
24 Jun 2012 22:35Oppinions will vary, but on my kz1000r I put a 3" lower tripple, like the s1. No old 80's road race kaws used a brace that I have found, and the large surface of my lower really helped.just my .02.ty.steve
- KraZyRIDER
25 Jun 2012 01:22
...well, I figured the 650 could use a little help in the front end department and ordered a brace from Fast from the Past. I needed linkage parts for rear sets, so I just added it to the order.
...it's only money, right?
...I keep telling myself that. It seems to lessen the pain. :dry:
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
- trianglelaguna
25 Jun 2012 01:55
good tires and good fork springs,fork oil, and right tire pressure ,tire balance, are needed first...but i had one and it was ok...just ok....i could not tell much difference ...but they look cool and dont hurt the bike unless...the above are not correct...then they can cause hop or chatter by binding the fronts ability to flex and react...imo
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- KraZyRIDER
25 Jun 2012 02:06trianglelaguna wrote: good tires and good fork springs,fork oil, and right tire pressure ,tire balance, are needed first...but i had one and it was ok...just ok....i could not tell much difference ...but they look cool and dont hurt the bike unless...the above are not correct...then they can cause hop or chatter by binding the fronts ability to flex and react...imo
...good point!
...everything you mentioned will be new.
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
- loudhvx
27 Jun 2012 01:27 - 27 Jun 2012 01:28
Telefix. I have several.
$100~$125
Made a noticeable difference on bumpy roads. I was then able to replace the factory steel fender with a fiberglass one.
I think I got them on Ebay.
I only like the ones that are adjustable for spacing between fork legs.
$100~$125
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 27 Jun 2012 01:28 by loudhvx.
