1982 KZ1000k ltd speedo speed sensor failed. Repairable ?
Re: 1982 KZ1000k ltd speedo speed sensor failed. Repairable ?
24 Oct 2023 11:47
Might seem like a stupid question but I am assuming the sleeve is under the circlip that retains the bearing so that it is engaged with the wheel ? If so measure the height and measure the depth of the sensor and you should be able to tell if it is all engaging as it should
- kz650guy123
24 Oct 2023 17:17
Hi Wookie
Yes the sleeve is under the circlip.
I did measure it. And it isn't long enough to engage the slots.
Kind of why I came to the conclusion that it may be the wrong wheel.
24 Oct 2023 22:57
Can you make one that is long enough or get somebody to extend the tube if you don't have welding kit ?
- cartal
22 Feb 2025 11:36
Guys, trying to find why my speedo does not work, y arrived to this thread. I took my speedo drive apart to find that the tangs that are supposed to be pulling the drive around are kind of bent inwards.
i think I can try to streighten them ok but would like to get some confirmation that effectively you see the same I do.
I guess I did not assemble the part correctly, and the fork axis pressure, just drove them “in”.
any advice, please? Some pics for reference
- Saablord
22 Feb 2025 11:56 - 22 Feb 2025 11:57
Yes, bend them out, but you may have to massage the tube back into a circle, not an oval.
Or I have one I could sell you as I'll be converting to a GPS speedo and removing the sensor. Not sure on it's condition though...its a bit bent like yours but still seems to work
Last edit: 22 Feb 2025 11:57 by Saablord.
The following user(s) said Thank You: cartal
22 Feb 2025 12:06 - 22 Feb 2025 12:06
Carlos these are the dimensions I measured for the other guy (and how it should look) - carefully straighten
Last edit: 22 Feb 2025 12:06 by Wookie58.
- cartal
22 Feb 2025 12:45
Well, that worked well. Apparently “tangs” are straight. I managed to find a 1/4 socket that fitted perfectly and also got the entire thing back to circular rather than oval.
Will try it tomorrow. Thank you guys!
The following user(s) said Thank You: Saablord, Wookie58
22 Feb 2025 15:00
Nicely done.
- Saablord
24 Feb 2025 17:43 - 24 Feb 2025 17:46
FYI, here is what they look like inside.
They are assembled similar to the gauges with a peened over edge and gasket. You could probably get it open and tig weld/epoxy it shut, if you had reason to (ie, could rig up a new hall effect sensor).
Only marking on the electronics is n3006 sk102.
Last edit: 24 Feb 2025 17:46 by Saablord.
25 Feb 2025 00:13I think that one will need more than a little "araldite" !!!!!!FYI, here is what they look like inside.
- Saablord
25 Feb 2025 11:02
Yeah... I try not to hack up OEM parts like this, but my gauges were trash and the 28(?)pulse per rev wasn't really compatible with aftermarket gauges. I went with GPS and so I cut this apart for the steel bushing.
Seeing this now, I probably could've tweaked the wheel to send out fewer pulses per rev 🤷 oh well
- cartal
27 Feb 2025 23:02
Seems like I cannot get it to work. There will be no reading, so initially I thought I was unable to assemble it the right way, but I am thinking now that the tangs are not long enough. Will take them apart again this weekend, and measure tangs against your measurements, Wookie.
Saablord, that carnage looks a lot to the things I usually do
If my measurements are not up to spec, I may take up your offer on the used part.
Thank you!
Thank you!
