Yuasa battery
  • gordone
  • gordone's Avatar Topic Author
Re: Yuasa battery
26 Nov 2020 13:46
#839001
I was thinking about the first time I charge it after I have filled it with acid, if I needed a special charger the first time.
After some googling the conclusion is NO :)
Project:
  • seanbarney41
  • seanbarney41's Avatar
  • '79 kz1000 LTD '75 Honda CB750
Re: Yuasa battery
26 Nov 2020 18:34
#839016
You have to be careful with kz650's. I see a lot of sellers listing a battery that is just slightly too tall. It will work perfectly but your seat will contact + and - on the bigger bumps which, of course, makes for badness. The situation can be remedied with some heavy rubber covers over the battery posts. It seems like the correct size battery is not available from many manufacturers, so they have substituted the nearest size that "almost" works,
  • gordone
Re: Yuasa battery
26 Nov 2020 23:13 - 26 Nov 2020 23:13
#839025
seanbarney41 wrote: You have to be careful with kz650's. I see a lot of sellers listing a battery that is just slightly too tall. It will work perfectly but your seat will contact + and - on the bigger bumps which, of course, makes for badness. The situation can be remedied with some heavy rubber covers over the battery posts. It seems like the correct size battery is not available from many manufacturers, so they have substituted the nearest size that "almost" works,
Thank you, the mesaurments seller have listed on ebay is lower then the cheap battery I have now, so I think it shall be good.
www.ebay.com/vod/FetchOrderDetails?sspag...ransid=2185752530008
Project:
Last edit: 26 Nov 2020 23:13 by gordone.
  • gordone
Re: Yuasa battery
27 Nov 2020 02:42
#839028
I`m now owner of
ctek XS 0.8 UK
www.ctek.com/uk/products/car/xs-0-8-uk
Project:
