gd4now wrote: Both of the screws shown in the picture appear to be pilot screws - notice the end a screw driver would interface with it is knurled which is what all of the pilot screws I have seen are like and none of the air screws I have see are like.
According to streetfigher, they both were removed from the pilot screw locations, bottom of carb on engine side of the carb as opposed to the air screw location on the air filter side on the carb. I suppose someone in the past could of installed something different than stock, but I just have never seen any pilot screws with the blunt end like these have other than some that the tip has broken off of.
Something that does not appear to have asked, are all 4 of the screws from the original carbs blunt like the one in the picture? Or is it the only one that way?
BlackZ1R wrote: The carb mounting flange, to me, would be the portion that mounts into the intake manifold boots on the cylinder head.
gd4now wrote: Something that does not appear to have asked, are all 4 of the screws from the original carbs blunt like the one in the picture? Or is it the only one that way?
gd4now wrote: I guess another thing that should be asked is there anything (the pointed tip) still sticking up into the carb throat where the pilot screw enters the carb?
gd4now wrote: ...air screws do have blunt ends, certainly much more so than the pilot screws I have seen do. But I have never seen air screw with the knurled ends on them like the pilot screws have. To my way of thinking they would not fit into the air screw ports with that end on them. Instead they would stick out - the air screws I have seen have smooth ends on them with the slot cut directly into them.....
