Dropping stock air box
  • likes2gofast2009
  • likes2gofast2009's Avatar Topic Author
25 Feb 2010 19:30
#350185
Bike is 1980 KZ1000 LTD. Bike is totally stock. This winter I am going with cone filters, 125 main jets and a strait pipe. I am totally new to bikes so bare with me here.
Ok so I am going with cones and getting rid of the stock air box. I got ahold of a valve cover without the emission ports so it will make it easier to drop all the emissions lines.
The only thing I am confused about is what to do about the small lines that go from the top portion of the box (the part that looks like a sphere) to the carbs. Are those some sort of vacuum lines? Where will those lines go once I remove the air box?
1980 KZ1000 LTD "Brandi"
4-1 Kerker
Dyna Coils
More to come this winter!
  • switch
  • switch's Avatar
  • 1981 KZ1000m CSR
Re: Dropping stock air box
26 Feb 2010 00:22 - 26 Feb 2010 00:23
#350228
gofast,
all your carbs but one will be capped where the vacuum lines connect. The one will be vacuum to the petcock. I tried this mod and found that there were some issues with jetting and riding in the rain. My advise is to KEEP the airbox. You may wish to restore the airbox at a future date (as I did) and all you will have to do is get a furniture plug to plug the hole in the top of the airbox.
I believe this is correct , but if it's not, there will be someone to set the record straight.
Good Luck, enjoy, shiny side up.
1981 KZ1000 M1 CSR
2004 Vulcan 1500 Classic (gone)
You do not have to believe everything you think!
Last edit: 26 Feb 2010 00:23 by switch.
  • chance
  • chance's Avatar
  • Life long biker/
26 Feb 2010 08:44
#350271
Those are vents I'm sure but check..Start your motor and see if they pull vacuum if they do cap em if not they must be vents. I think the 80 has vm26s so with pods and open pipe your jetting should be 120/20..:)
  • chance
  • chance's Avatar
  • Life long biker/
26 Feb 2010 08:51
#350272
Also you could use the early Z1 airbox has its easier the remove for carb removal. or something like this..
  • likes2gofast2009
26 Feb 2010 16:23
#350309
Alright so does 120/20 mean 120 main and 20 pilots jets?
4-1 Kerker
Dyna Coils
  • chance
  • chance's Avatar
  • Life long biker/
27 Feb 2010 17:34
#350443
Yes Sir.Correct
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
27 Feb 2010 18:15
#350449
Hey Guy,
These bikes are plenty fast. While you're out looking for more horsepower don't dismiss rideability. At the very least don't sell your stock airbox, you may change your mind after you've experienced the joys of carb tuning.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • trianglelaguna
  • trianglelaguna's Avatar
27 Feb 2010 18:26
#350452
airbox=
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • larrycavan
  • larrycavan's Avatar
28 Feb 2010 05:49 - 28 Feb 2010 05:54
#350502
FIRST - There is no vacuum line to the petcock on that model. Those are both fuel hoses on the petcock.
If you remove the clean air system, you need to seal the hole in the airbox where the fresh air hose connected.
If you're going to street ride this bike with stock carbs and a pipe, LEAVE THE AIRBOX ON IT & remove the rear silencer section of the airbox under the seat.
With that removed, you can use an OEM Style replacement air filter or remove that filter and find a K&N filter that will clamp to the airbox where the silencer section mounted.
YOU WILL NOT SEE HUGE PERFORMANCE GAINS FROM REMOVING THE AIRBOX AND REJETTING THE CARBS.
After installing a pipe, you may need to do some jetting. That cannot be determined until the pipe is on the bike and you ride it.
Stock jetting on your bike should be.
102.5 MJ
#15 long pilot
O-1 Needle Jet [the leanest needle jet ever from the factory]
5CN29 needle with a single clip groove.
If you needed to richen the midrange, I would swap the 5CN29 needles for some 5DL31 needles.
While in there you might also jump the main jets to 107.5 then install the carbs and airbox w/o the rear silencer.
Changing jets on the stock carbs with the airbox on is difficult. It's tough getting the carbs in and out. But for the overall, that stock airbox is the best ticket...
JMO
Larry C
Last edit: 28 Feb 2010 05:54 by larrycavan.
  • chance
  • chance's Avatar
  • Life long biker/
28 Feb 2010 08:35 - 28 Feb 2010 10:50
#350548
Vents those should go somewhere thats not hot ..those lines will leak out gas if you take a spill so you wouldn't want then to drip on anything hot like exhaust.. Mine go in front the swingarm..
Pics would help greatly..Thanks
Last edit: 28 Feb 2010 10:50 by chance.
  • muddy1
  • muddy1's Avatar
  • 1980 Kz1000 LTD B4
02 Mar 2010 16:14
#350919
how are the boots on the airbox? Are they soft or hard?
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
  • likes2gofast2009
04 Mar 2010 11:19
#351255
The bike is back home so I am unable to get any pics right now or check to see if those lines pull vacuum.
I guess the bike isn't completely stock like I lead on but pretty much it is. All it has done is a 4-1 kerker header with a mac pipe and then dyna coils. I did take the baffle out of the pipe though because I am planning on jetting and a local KZ guy said that it wouldn't run right with the baffle once I jetted it.
I still kinda want to stick with the cones and 120/20. Would that be better since my bike is already piped and what not? Also how big of a risk is it to run cones if I get caught in the rain?
ps. I plan on keeping all of the stock equipment just incase I need to switch everything back over.
4-1 Kerker
Dyna Coils
