new kz owner
- 1904
new kz owner
14 Sep 2006 21:01
Hi all, i was just given a 1980 kz750b twin. It looks to be complete, and well taken care of. I drained the oil tonight, looks really clean. I think its just been sitting for a while. My goal is to get it up and running for as little as possible. The coil and plug wires look to be trashed, is there a source for these? Also it looks like water got into the switches on the handle bars and they need to be replaced. Also need some other little things to get it running. any advice, or info or links for parts woul dbe greatly appritiated. thanks
- Shoe48
- Live each day as it is your last
Re: new kz owner
14 Sep 2006 21:11
As far as parts . Look in the Classifieds then Good Ole Ebay , I happen to know there are a lot of twin parts on right now ,Lets not Forget Z1 enterprises , The Guys here are top notch ,, Really know what they are talking about ,, Welcome aboard ,, Shoeman
- 1904
Re: new kz owner
14 Sep 2006 21:13
do you have any suggestions on finding a good coil , the one i have looks ok, but the wires are trashed, and they are molded into the coil, so im guesing i have to replace the whole thing? OR maybe theres somthing else i can rig up one the cheap? thanks
- grace1
Re: new kz owner
15 Sep 2006 01:14
G,DAY
WELCOME \I THINK THERE IS A COIL ON EBAY THIS WEEK
BE CAREFULL OF SWITCH PRICES ,ACTUALLY IN OSS DOWN UNDER OUR Z900 AND Z750 TWINS HAD THE SAME SWITCHES .SO SHOP AROUND EVEN FOR 900,SWITCH GEAR IT PROBALLY IS ALL THE SAME THERE
OR IF YOUR ADVENTUROUS PULL THE SWITCHES APART AND CLEAN WITH CRC ,WD40 OR THE LIKE AND REASEMBLE
I,LL TRY TO SHOW YOU MY TWIN ,DONT HAVE MUCH LUCK WITH PICS BUT HERE GOES
CHEERS GRAEME FROM THE LAND DOWN UNDER
bendigo australia, gold mine country
MY COLLECTION 1978 B3 KZ750 AND 1980 GS1000G
- steell
Re: new kz owner
15 Sep 2006 04:08
The switches can be taken apart and cleaned.
I think a brand new Dyna coil is around $70, and that's a better deal than a 25 year old coil for $25, in my opinion anyway.
On the right side switch pod there is a place where it says something like "Lights, on off" and it looks like the knob is broken off, it's not, there is (or supposed to be) a block off plate for that switch.
Kawasaki use the same switch pods for the 76-80 750 twins, they just blocked off that switch for the 79-80 models.
- cnyl
Re: new kz owner
15 Sep 2006 06:20
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
North Port, FL
Check out my band
- tw..
Re: new kz owner
15 Sep 2006 06:36
also if you need parts diagrams or break downs go to
www.buykawasaki.com
having access to those parts break downs saved me more times than i care to mention.
tom
tom
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
1978 Z1R
- steell
Re: new kz owner
15 Sep 2006 06:57
General info:
If it looks like the one to the left (my avatar), it is a KZ750 "G", not a "B". B models were 76-79, G was 1980, M was 1982, and K was 1983 (belt drive).
I'm not being nitpicky, the differences are important. The 76-79 carb kit won't work on the 80 G model for instance. Lot's of other differences, most minor, a few major.
- 1904
Re: new kz owner
15 Sep 2006 21:01
thanks for all the replys, im going to try to keep costs way down and just get it to run first. So i need to get ahold of a coil and wires, the dyna stuff looks nice, i couldnt find one for less than 150 bucks. I will probably throw some generic switches on it also.
- steell
Re: new kz owner
15 Sep 2006 21:28
You only need a single coil, and I think it's less than $70 at Z1 Enterprises
Any 3 ohm motorcycle dual output coil that you can mount will work.
- pumps
Re: new kz owner
15 Sep 2006 22:38
For me, to clean/lubricate switches and lubricate small electric motors I use some stuff you can buy at the electronic supply house called De-Oxit. Radio Shack has something similiar I recall. Shoot it right into the switch..work it back and forth. Its amazing what it does. I would try that before I go spending lots of $$$ on new or ebayed ones . You may have to but why if you don't?
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
1977 Yamaha XS650
2000 Kaw W650
- 1904
Re: new kz owner
16 Sep 2006 12:04
can somone tell me how much oil, my bike holds. I ordered the manual but havnt gotten it yet
