APE nuts
Re: APE nuts
01 Jun 2023 05:47
- Cra-z1
Re: APE nuts
01 Jun 2023 08:20 - 01 Jun 2023 08:23
Last edit: 01 Jun 2023 08:23 by SWest.
Re: APE nuts
01 Jun 2023 12:30 - 01 Jun 2023 12:31
A nice set of polished stainless steel nuts for 4 and 6 cyl. bikes (ebay.com/itm/114286618817 and ebay.com/itm/115429409094)
Last edit: 01 Jun 2023 12:31 by Scirocco.
The following user(s) said Thank You: Injected, daveo, Mikaw, Wookie58
- Injected
Re: APE nuts
01 Jun 2023 13:24
Do you know why the aftermarket nuts are taller or don't have a top on them?
Because you need the extra height when decking the barrel or cylinder head, a short stock nut will bottom out on the stud.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
- gordone
Re: APE nuts
01 Jun 2023 14:11
Saving weight, by having open nut?
Project:
Project:
- Injected
Re: APE nuts
04 Jun 2023 08:22What did you end up doing to solve the issue?Hey dumb question: you guys using oversized head studs on 900/1000s, how do you seal the outside four nuts so they don’t piss oil? These are the open top nuts, not the closed ones.
