Lockup clutch or not for the street
  • tomsbadkz
  • tomsbadkz's Avatar Topic Author
01 Jul 2015 15:19
#678986
I am building a Pro Street KZ1000. I'm running a 300 tire with air shifter. MRE trans with billet 2nd gear. The bottom end is a 1327 10.5 and the head is a 83-84 GPZ1100 head done by Larry Cavanaugh flowing over 100cfm. It's going to be ridden occasionally and once in a while at the drag strip. I was wanting some feedback about a lockup clutch whether it's necessary or not. :unsure: Thanks guys.
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Lockup clutch or not for the street
01 Jul 2015 18:25
#679023
tomsbadkz wrote: I am building a Pro Street KZ1000. I'm running a 300 tire with air shifter. MRE trans with billet 2nd gear. The bottom end is a 1327 10.5 and the head is a 83-84 GPZ1100 head done by Larry Cavanaugh flowing over 100cfm. It's going to be ridden occasionally and once in a while at the drag strip. I was wanting some feedback about a lockup clutch whether it's necessary or not. :unsure: Thanks guys.
Hey Tom
Most guys I know run them on high powered bikes, You don't mention what clutch combo you run so I can only guess.
Lock ups are more important on turbo bikes than other bikes as we make more power up higher in the rpm range and that is where our bikes really start slipping the clutches. You wont need one until you start eating clutch plates, or be proactive and put it on now
Dave B) B) B)
  • tomsbadkz
01 Jul 2015 18:45
#679029
I'm using a FBG welded clucth basket with HD springs, also the bearing style pusher and kevlar friction plates. I just got a really good deal on a barely used MTC lockup and MTC cover. I had one on my other kz with a 1385 11.1 to1 street motor. Seemed to work but i was fairly new at this degree of KZ fun.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
  • Moderator
  • Moderator
01 Jul 2015 19:02
#679035
Then put it on and enjoy
I have not burnt up a clutch since I put my Karata Glide on many miles, and years ago
Dave B) B) B)
  • tomsbadkz
01 Jul 2015 19:07
#679036
thanks Dave. want it to last and go fast. there are some really good knowledgable people on here, present company included. ;)
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
02 Jul 2015 04:01
#679076
I run stock springs with my lockup, very easy on the hands with light clutch pressure. I've seen littler motors than yours need them so go for it, You won't regret.
Les
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
02 Jul 2015 06:25
#679095
i think a lockup is one of the few performance products that has absolutely no draw back.
  • Moderator
  • Moderator
02 Jul 2015 06:31
#679096
les holt wrote: I run stock springs with my lockup, very easy on the hands with light clutch pressure. I've seen littler motors than yours need them so go for it, You won't regret.
Les
+1 on the lite springs
. You can run the HD springs ( I do ) But it is probably overkill.
I installed them pre turbo with a HD clutch with extra plates ( Action 4 , a Bill Hahn company from the distant past ) so I kept them . But my clutch lever needs a heavy hand. Maybe one of these days I will lighten them up
Dave B) B) B)
  • SWest
  • SWest's Avatar
  • 10 22 2014
02 Jul 2015 10:58
#679121
I've been planning on copying what zukedave did to his clutch arm. Make it a little longer, less pull tension required. I've got my eye on some NOS ones in case I don't like it.
  • DFIGPZ
  • DFIGPZ's Avatar
02 Jul 2015 13:58
#679136
run the lockup as for springs you can use worn out stock springs or better yet use worn out H2 springs never run HD spring with lockup you are defeating purpose !
1984 750 Turbo
  • tomsbadkz
02 Jul 2015 17:26
#679160
thanks DFIGPZ. we have to get together for assembly soon. Child support is DONE!!!!!!!! :silly:
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
  • tomsbadkz
08 Jul 2015 14:59
#680070
This is the lockup i bought for under $90.00 Let me know what you guys think. i think this will work for what i described earlier in this article.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
