1979 KZ1000st spark plug gap 0.028-0.032in
- kzboy
08 Aug 2011 18:02
Spark plug gap in my CLYMERS book said 0.028-0.032in. Any idea out there if I should go with the high or low number?
- otakar
Re: 1979 KZ1000st spark plug gap 0.028-0.032in
08 Aug 2011 18:05
Depending on your coils. If these are the original 32 yer old coils than go with the smaller. If they are replacement OE coils than go with the larger. If they are aftermarket hi output coils you can go .040"
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- MFolks
08 Aug 2011 18:08
All sparkplugs wear over time, so by starting at the low end of the gap spacing, the plugs will gradually increase. Are you using the as supplied ignition coils,sparkplug wires and sparkplug caps? You ignition parts are 32 year old! Past time for replacements/upgrades.
Ignition Systems & Ignition Coils
www.msdpowersports.com/mc-3.html
www.dynaonline.com/skins/products/sportbikes/dyna_s/
www.accel-motorcycle.com/ProductDetails....on=2&minselection=19
www.jpcycles.com/product/381-326
Still got the points?
- kzboy
08 Aug 2011 18:13 - 08 Aug 2011 18:13
Yeah, ignition is original and coils have cracks that I tried to repair once apon a time. I will go with the smaller of the 2 gaps as said.
Last edit: 08 Aug 2011 18:13 by kzboy.
- Motor Head
08 Aug 2011 20:56
If your coils are cracked, you would be wise to replace them. Get some higher output coils for the bike, it will help it a fair bit. That is if your wiring is good so the voltage gets there to power them.
- kzboy
08 Aug 2011 22:44
what causes the coils to crack?
- otakar
08 Aug 2011 23:18kzboy wrote: what causes the coils to crack?
Heat and time. It is not uncommon on coils that old.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
08 Aug 2011 23:19Motor Head wrote: If your coils are cracked, you would be wise to replace them. Get some higher output coils for the bike, it will help it a fair bit. That is if your wiring is good so the voltage gets there to power them.
100% agree
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- MFolks
08 Aug 2011 23:20
Even when the new, the ignition coils were marginal, put some years on them with stop and go traffic, and they will cook/overheat. Where they're mounted also traps the engine heat.
If your coils have cracks, moisture will get inside, shorting out the windings making for weak to no spark possibly stranding you.
- RonKZ650
09 Aug 2011 00:04
My ST only has 4000 miles on it and both coils have big cracks in them. It runs fine that way so I don't care to fool with them since I ride it all of 10 or 15 miles every couple years.
- otakar
09 Aug 2011 10:16
You could burn out the ignition if the coils start arcing internally.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
