She just dies when i try to let out the clutch
  • kawman66
  • kawman66's Avatar
Re: She just dies when i try to let out the clutch
01 Apr 2011 21:41
#442044
badr0bot wrote: kawman, I can walk the bike forward in gear with the clutch pulled in. I can feel a little drag but it doesn't seem like enough to kill it.
yea its not a clutch stuck problem it prolly is in the advance.
75 z1b
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
my drinking team has a racing problem
  • badr0bot
  • badr0bot's Avatar Topic Author
01 Apr 2011 22:39
#442058
The advance turns freely. It wasn't sticking at all. Any other ideas? What might cause an engine to run and rev great but bog down and refuse to run under even a slight load?
87 KZ1000 P1
  • vernons
  • vernons's Avatar
01 Apr 2011 22:40
#442059
hey guy's. i had the same problem with my kz last yr after i bought it.. was really hard to take off without killing it.. i thought i had lost my touch riding a bike!!! plus mine was super hard to start, like an old harley... talked to an old time kz mechanic here in tulsa.. i have a dyna ignition.. he said it was easy for them to stick fully advanced... that was my problem.. it had been stuck on the previos owner for a long time.
starts and runs so easy after unsticking the advance!! so much easier to ride.. and i hadn't lost my touch riding after all.. something so simple can really be a pain!!!!
good luck
  • vernons
  • vernons's Avatar
01 Apr 2011 22:53
#442064
maybe it's not advancing at all?? instead of being stuck fully advanced..
  • kawman66
  • kawman66's Avatar
01 Apr 2011 23:02
#442066
are the carbs clean. some times the pilot jet will get clogged.
75 z1b
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
01 Apr 2011 23:48
#442086
badr0bot wrote: The advance turns freely. It wasn't sticking at all. Any other ideas? What might cause an engine to run and rev great but bog down and refuse to run under even a slight load?
Are valve clearances within specs? :unsure:
Air filter blocked or dirty or over-oiled? :unsure:
Adequate fuel supply into carbs? :unsure:
Good Fortune! :)
  • badr0bot
02 Apr 2011 00:42
#442098
Well miraculously she just started working. I posted my last comment before I put the ignition back together. The only thing I can think of is that it may have been stuck and just twisting it by hand freed it. The only question still lingering in my mind is why would a stuck advance mechanism result in no power? I would think that you would see a misfire when revving at higher rpms which didnt happen.
87 KZ1000 P1
  • testarossa
  • testarossa's Avatar
02 Apr 2011 00:51
#442101
Just my opinion, but an engine operating under a load vs. no load are two completely different situations.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
02 Apr 2011 01:02 - 02 Apr 2011 01:03
#442103
badr0bot wrote: Well miraculously she just started working. I posted my last comment before I put the ignition back together. The only thing I can think of is that it may have been stuck and just twisting it by hand freed it. The only question still lingering in my mind is why would a stuck advance mechanism result in no power? I would think that you would see a misfire when revving at higher rpms which didnt happen.
Not so noticeable where engine is running in neutral and the advancer is stuck in idle position, because the engine revs relatively freely under these conditions without any load.
Would lube the advancer, and perhaps both clean and lube.
Good Fortune! :)
Last edit: 02 Apr 2011 01:03 by Patton.
  • TexasKZ
  • TexasKZ's Avatar
02 Apr 2011 11:01
#442136
Is there a side stand switch?
  • badr0bot
02 Jul 2011 16:19
#460656
Update: It was the side stand switch. Just pulled it out and bypassed.
87 KZ1000 P1
