Engine oil turns black 50 miles after oil change
- onanysunday
Re: Engine oil turns black 50 miles after oil chang
01 Dec 2009 18:47
ok, thanks.
79 KZ1000 E-1
VM28SS
K&N Pods
VM28SS
K&N Pods
- bountyhunter
Re: Engine oil turns black 50 miles after oil change
01 Dec 2009 22:57
onanysunday wrote:
The problem is most name brand oils are eliminating zinc and phos additives and any flat tappet engine really needs them. I add a some ZDDPlus to mine to be safe.I like the 15w-45 viscosity of Rotella. I buy the 4 qt. jugs for about $9. I thought of using even cheaper car oils but I thought smaller motorcycle engines had different additive package requirements-something about different Ash or Zinc requirements than car engines? Is that true?
- otakar
02 Dec 2009 03:57
bountyhunter wrote:
This is correct, Zinc and Sulfur, which are necessary for our engines are bring removed. The problem with ZDDPluss is that it more than doubles the price of the oil. For $8+ a bottle which treats 5qts. it is outrageous. I use Red Line Additive which costs $12 and treats 16+ Quarts. If you use Rotella-T you do not have to worry about it at all. Rotella has the Zinc and Sulfur and I pay about $8 at Wall-mart for it. I bought ZDDPluss once and it was a ripoff. If you want to use an additive use the Red-Line.onanysunday wrote:The problem is most name brand oils are eliminating zinc and phos additives and any flat tappet engine really needs them. I add a some ZDDPlus to mine to be safe.I like the 15w-45 viscosity of Rotella. I buy the 4 qt. jugs for about $9. I thought of using even cheaper car oils but I thought smaller motorcycle engines had different additive package requirements-something about different Ash or Zinc requirements than car engines? Is that true?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- RonKZ650
02 Dec 2009 06:45 - 02 Dec 2009 06:51
I've been running Rotella for 20 years in trucks and been getting the oil analysis from Blackstone for the last several years. Just for info, the zinc level has not dropped in the new CJ-4/SM formulation compared to the older SL. Actually my zinc level with was 1251PPM average with SL Rotella and 1319PPM with SM. Even in an email to Shell with my worries about reading the horror storys (cams rounding off in 100 miles), they said zinc levels are still higher in the oil and "use it without worry". So that's my opinion due to my own research. As to phosphorus, average level with SL was 1242PPM, SM 1244PPM so virtually identical there. A lot of goofy info being distributed about the new oil. Oil is the best it's ever been, using a SF rated oil is just like using 15yr old tires vs modern rubber. No need to second guess the oil additives and add your own.
Last edit: 02 Dec 2009 06:51 by RonKZ650.
- onanysunday
02 Dec 2009 10:57
Ok, I'll stick with Rotella-T. Thanks.
79 KZ1000 E-1
VM28SS
K&N Pods
VM28SS
K&N Pods
- bountyhunter
02 Dec 2009 19:34 - 02 Dec 2009 19:40
otakar wrote:
Exactly how much you need is another question, but I believe the ZDDPlus added as prescribed increases the zinc/phos about 2500ppm which is the high end of best range. I recall you could not add enough redline to get near that. ZDDPlus is pricey, but you only need a "half shot" to bump a five quart change up about 1500 ppm as I recall.
If I did it wrong, maybe the numbers are off. But, I am the original skinflint and I recall doing the calcs and coming to the conclusion the ZDDP gives more for your $$$ in zinc/phos than redline. Also, it's more concentrated so you "displace" less oil to get it in the mix.
I think redline is OK stuff, but I think the ZDDPlus can get a higher concentration going. To be sure, many engines don't need a 1500 - 2000ppm bump but the high lift cams might. Redline is probably good for the majority of cases.
regards, apologies if my math is off.
Maybe so, but I recall I wnt to the MSDS sheets on both the redline stuff and ZDDPlus to calculate concentrations of zinc/phos and the ZDDPlus is WAYYY more concentrated. The redline recommends a certain dilution, but does not give anywhere near what ZDDP does because it's more concentrated.bountyhunter wrote:This is correct, Zinc and Sulfur, which are necessary for our engines are bring removed. The problem with ZDDPluss is that it more than doubles the price of the oil. For $8+ a bottle which treats 5qts. it is outrageous. I use Red Line Additive which costs $12 and treats 16+ Quarts. If you use Rotella-T you do not have to worry about it at all. Rotella has the Zinc and Sulfur and I pay about $8 at Wall-mart for it. I bought ZDDPluss once and it was a ripoff. If you want to use an additive use the Red-Line.onanysunday wrote:The problem is most name brand oils are eliminating zinc and phos additives and any flat tappet engine really needs them. I add a some ZDDPlus to mine to be safe.I like the 15w-45 viscosity of Rotella. I buy the 4 qt. jugs for about $9. I thought of using even cheaper car oils but I thought smaller motorcycle engines had different additive package requirements-something about different Ash or Zinc requirements than car engines? Is that true?
Last edit: 02 Dec 2009 19:40 by bountyhunter.
- bountyhunter
02 Dec 2009 19:37
onanysunday wrote:
The only fear is they can change the formula without warning or notice.
It's probably the one oil (along with amsoil synthetic) that I have never heard a bad word about.Ok, I'll stick with Rotella-T. Thanks.
- polkat
05 Dec 2009 00:28 - 05 Dec 2009 00:30
All internal combustion engines, even rebuilt and new ones, have a small amount of blowby. It is inherant in the design of ringed piston engines. Somewhat worn engines have even more, and you mentioned seeing smoke (I assume oil smoke) at times. This can mean something is beginning to wear, and when you start to get wear in one area (possibly intake valve guides), you start getting wear in all areas. This along with heat (and sometimes heat alone) will turn new oil dark quite quickly. When the effect is minimal, you probably won't notice much oil compsumtion.
All of this is normal, and if your compression, plug readings, etc are correct, and you don't feel any grit in the oil or see junk in the filter, you've probably got nothing to worry about. I used to build pro-stock Mopar engines. We built them somewhat loose. Fantastic power, but the oil would blacken in 2 runs. Normal.
Last edit: 05 Dec 2009 00:30 by polkat.
- toad
07 Apr 2010 04:51
diesel oil turns black quick, no worries..
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- Motor Head
07 Apr 2010 05:27
Keep in mind that like the Bikes, Cars are 4cyl DOHC for many years and Motor oils have developed for running in these much closer tolerance higher RPM engines. Myself I wouldn't buy the Bike motor oil when it is so expensive, there are to many other oils that meet or beat it for much less. Some may say that the additives are different for the wet clutch, but I've never had any clutch issue from a oil.
- Bluemeanie
07 Apr 2010 06:22 - 07 Apr 2010 06:23
Interesting thread. I've been using Parts Master 20-50 which is the local parts stores oil (made by Valvoline) Worked great and no problems at all with 1,000 mile changes and filter every other change. Changed oil with Valvoline 15-40 diesel last week and will see how it looks when change time comes.
Last edit: 07 Apr 2010 06:23 by Bluemeanie.
- sbc1320
07 Apr 2010 07:03
Black oil doesn't mean its bad. As long as the oil still has it's lubricating properties and isn't broken down, then it will be fine. Quickest way to loose a cam lobe on my car engines is to use a regular oil. Shell Rotella and some cam break in fluid is the way to go for any new engine. I run roller cams these days in my cars, so flat tappets are a thing of the past for my cars anyways.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
