Another Rotor Removal Problem
- 79MKII
- Love Them Kaws!
05 Mar 2006 15:10
Man, am I screwed now.
I have tried everything to get this rotor off my crank and it will not come off. I would like to try the slide hammer method but I'm not sure how I would connect the hammer to the rotor. Has anyone used a slide hammer for the rotor before? I tried heat, hammering, flywheel removal tool, air impact, no luck. The remover tool is now broken off in the rotor. I was able to drill it but the easy out just stripped out the hole without pulling it loose. The rotor is totally shot (I have a good spare) so I'm not worried about it at all, I just need it off my crank. Can anyone help? I have looked online for a slide hammer but nothing looks like the correct type. I don't think the jaw pullers would work. I am really worried here!What type of slide hammer might work?
Another thing to add: There is no starter clutch or gear or anything on this rotor, so I could possibly use the threaded holes in the rotor for a connection to the slide hammer (there are three holes where the starter clutch would normally attach from the inside). Not having an electric starter may work in my favor.
Post edited by: 79MKII, at: 2006/03/05 18:15
The Kaw List:
- wireman
- steell
Re: Another Rotor Removal Problem
05 Mar 2006 15:16
Whoo Boy! At this point I think you should seriously consider taking it to a machine shop and paying a professional to get it off. Sometimes biting the bullet and paying someone is the best and cheapest option.
- Shoe48
- Live each day as it is your last
05 Mar 2006 16:02
Ok What kinda of tool is suppose to be used ??
- wireman
05 Mar 2006 16:27
that should have a newer style rotor on it,but i dont have one handy here to look at!are there any bolt holes on the inside of rotor?:whistle:
- 79MKII
- Love Them Kaws!
05 Mar 2006 17:04
wireman wrote:
Yes, there are three threaded holes in the back that would normally hold the starter clutch. There are also 2 holes in the outside of the rotor where the special holder attaches. The rotor is totally stripped so there are no starter gears, no magnets, nothing. I'm sure there is a way to use a slide hammer but I was just hoping that someone had already done it so I would know what set up to use. I want to buy a slide hammer that will attach for sure. I will attach a scanned picture from my manaul. I don't have a digital here right now, so I'll post pics tomorrow sometime. This job shouldn't be this hard:angry:
Item "B" is what broke off in the rotor
Post edited by: 79MKII, at: 2006/03/05 20:09
The Kaw List:
- djturnz
07 Mar 2006 10:13
I threaded my rear axle into the rotor, with a large washer for the "bolt" end and used a 10lb barbell weight to slide down the axle as a slide hammer.
It didn't get mine off, but it works as a slide hammer.
1982 KZ750 (4) LTD
- Duck
- e vica na i sau na ga
07 Mar 2006 12:20
Looking at the photo, I wonder why one would want to apply a tangential force to the rotor, special tool 'A', if the rotor is interference fit on a taper.
What does the manual say to do with the two special tools?
My manual is not here.
-Duck
-Duck
- wireman
07 Mar 2006 12:27
tool a keeps the rotor from turning.tool b is the actual puller.
- Duck
07 Mar 2006 12:37
Ah Ha! I get it. Special tool 'B' presses on the end of the crank by way of threads inside the rotor and tool 'A' keeps the rotor from turning as tool 'B' gets tight.
If rotor is shot anyway and tool 'B' is broken in end of rotor, why not pack some towels behind rotor and cover the engine to keep the dust off and cut rotor off using a hand held abrasive saw?
-Duck
-Duck
- 79MKII
- Love Them Kaws!
07 Mar 2006 14:48
Duck wrote:
I've been trying to think of a way to cut off the rotor and not damage the crank. I may try using a friends torch to really get the rotor hot. I bit the bullet and bought a nice slide hammer/puller and heated the rotor with a propane torch, but no luck. That baby is stuck on there! Maybe if I can get it hot enough it will come loose with the slide hammer. But then I have to worry about the heat damaging the crank anyway...
I guess I'll try the heat, then try cutting it, then buy a new crank anyway!
-Duck
The Kaw List:
- 79MKII
- Love Them Kaws!
07 Mar 2006 14:50
djturnz wrote:
That sounds like a good idea. That was probably a lot cheaper than the $75 puller I bought (for nothing!). So, you never got yours off?
The Kaw List:
