100 hp KZ650
- steell
- kxhonda
Re: 100 hp KZ650
07 Aug 2008 19:54
Hmm, kinda seems like the angle leading into the chambers would really screw with the squish area. Almost seems like that chamber wouldn't be as efficient as the KZ's perfect hemispherical chamber. Where's LarryC when ya need him?
1977 Kz650B1 #576th made.
Warsaw, In
Warsaw, In
- mtkawboy
Re: 100 hp KZ650
07 Aug 2008 19:58
12.2's, thats really fast :S
- steveo_4192003
- 77kz650b-1
Re: 100 hp KZ650
07 Aug 2008 20:51 - 07 Aug 2008 22:08
dont the kz650s run low 12's from factory?
or is that the kz900!!!
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
Last edit: 07 Aug 2008 22:08 by steveo_4192003.
- kxhonda
Re: 100 hp KZ650
07 Aug 2008 20:58
Low 13's maybe. On a good day with a good rider.
Warsaw, In
Warsaw, In
- steell
Re: 100 hp KZ650
07 Aug 2008 21:30
kxhonda wrote:
You have to remember that it's a GPz750 head
The GPz750 pistons have a dome that matches that bevel, and if the engine is assembled at zero deck height, the piston will contact that bevel, or be within a very few thousandths of doing so.
Looks to me like it is a squish area, but instead of shooting the mixture across the top of the piston it sends it through the middle of the chamber, a good thing in my opinion.
I think I am either going to shave the head right up to the edge of the 45* angle of the intake valve seat and re-cut that angle, or shave the block to bring the piston up to zero deck height, depending on the results of some measuring when I test assemble the motor.
My current thinking is to have .030" between the piston top and that bevel, but I might reduce the clearance after taking measurements during the trial assembly, and I still need to figure out how much the motor expands when warmed up.
It gets tough when you run the ragged edge
- steell
Re: 100 hp KZ650
07 Aug 2008 21:40 - 07 Aug 2008 21:42Almost seems like that chamber wouldn't be as efficient as the KZ's perfect hemispherical chamber
Show me one modern high hp sport bike that uses a hemispherical combustion chamber
There has been a lot of research into combustion chamber effects since the days when the hemi was king, and it's been dethroned
A hemi chamber is actually terrible for making power, and Kawasaki started moving away from it in 1983 with the GPz1100 (and now it looks like the GPz750 also) head. Both the GPz1100 and the GPz750 chambers leave a lot to be desired, but at least they're a step in the right direction.
Last edit: 07 Aug 2008 21:42 by steell.
- bountyhunter
Re: 100 hp KZ650
07 Aug 2008 22:28
steell wrote:
What's the displacement on the GP bikes now? I thought it was about 750.
I guess it's 800cc now:
What 750 race bikes? As far as I know the Suzuki GSXR 750 killed 750 racing, they were winning every race. Kawasaki doesn't even make a 750 sport bike any more.
FIRST SHAKEDOWN TEST FOR THE DESMOSEDICI GP7
Factory test-rider Vittoriano Guareschi carries out the first shakedown test of the Ducati Desmosedici GP7, fitted with a new 800cc engine in compliance with 2007 MotoGP regulations.
- bountyhunter
Re: 100 hp KZ650
07 Aug 2008 22:41 - 07 Aug 2008 22:46
steell wrote:
steell wrote:
I never said 200HP from 45CID is typical for a street bike, I said (clearly) it was the limit if you want to throw a ton of money at it.
Unless you are talking drag racing, and even there a 200 hp non turbo 600 or 750 would have about as much in common with a street bike as Lorcan's new 1500cc Pro drag bike does.
steell wrote:
They claimed over 200HP from the 750 superbikes Kawi ran a few years back (about 5HP/CID). I didn't personally witness the testing. Yes, it is similar to F1, except that F1 is 2.4L which is 146 CID putting out over 900HP (normally aspirated) which is over 6HP/CID.You have a link for this 220 hp 750?? That's close to Formula One technology (1500cc 600 hp)
wiki.answers.com/Q/How_much_horse_power_...mula_1_race_car_haveHow much horse power does a Formula 1 race car have?
Answer
Formula One engines have anywhere between 800-1000 horsepower. It depends on the constructor. They also put out about 17000-19000rpm.
Last edit: 07 Aug 2008 22:46 by bountyhunter.
- steell
- mtkawboy
Re: 100 hp KZ650
08 Aug 2008 08:38
I only know of one 600 late model water cooled Kawasaki turbo bike thats been dynoed at 200hp. That belongs to Jon Amo and will be running at Bonneville next week or Bub's Bike Week if it isnt done in time. There may be others but thats the only one I know of and its a land speed bike with aerodynamic body work, a long way from a street bike. There is no 750 class so they have to run in the 1000 class, 1000 cc's being the upper limit. They may be enlarged up to that number if possable. His brother Joe runs a 245 mph Zx10 turbo and holds the record and is faster then most turbo Busas. I believe Jon has run 198 but broke trying to back the record up
- steell
Re: 100 hp KZ650
08 Aug 2008 10:35 - 08 Aug 2008 11:53
Is Bub's Bike week the one on the East Coast? If not, do you know the name of the East Coast Land Speed event? I really want to take the 750 Turbo there in it's current tune to see what it will do before we upgrade it over the winter.
201 mph is all I ask, I just "have" to break 200
Water cooling makes things so much easier
Edit:
Found it! ECTA, runs at Maxton North Carolina, 508 miles from here according to Google Maps.
Edit:
Last edit: 08 Aug 2008 11:53 by steell.
