KZ900: Value of this bike
- redhawk4
Re: KZ900: Value of this bike
24 Jan 2016 07:12
That's the other problem with a mint low mileage "stocker", you will never want to ride it any distance - go Swest it's great to see some one really riding these bikes
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
- VMASS
24 Jan 2016 07:41
Pulled the carbs and cam cover. Identifying marks on the cams:
CWC
EP14
A29
Made in USA
I will post some pics momentarily.
CWC
EP14
A29
Made in USA
- VMASS
The following user(s) said Thank You: 750Kruzer
- VMASS
- Rockranch
24 Jan 2016 07:48Vroom -vroom!!!--Waaaaaaadnnnn-waaaaaaaaaaadnnnn-WAAAAAAAAAAAAAAAADNNNNN!!! Rock on!..................................................Mikeswest wrote: I agree. I could have brought back to stock including a used frame. I decided to have all the goodies I ever wanted and RIDE THE PISS OUT OF IT. :woohoo:
(2)-1976 KZ900B-LTD's
1-all stock low mileage...
1 modified
1977 KZ1000 (awaiting resurrection!)
...and an old school Honda CB750 Chopper is next on my bucket list!
Oh...and a Pocket Rocket lol!!!
1 modified
- z1kzonly
24 Jan 2016 08:44 - 24 Jan 2016 08:46
Nice! Even more value. Cycle Works cams, Do I detect a little relief cut into the head at the valve bucket in 1 of the pictures? (hey do this for overlapping with the cam lobe at high RPM's. I don't know the # of the cam from what you posted. There will be a stamp in the ends of the camshafts were those blue Manley plugs are. But nice drop in cams in excellent shape. Also heavy duty cam chain with aftermarket cam sprockets, though not adjustable. The crank is welded too, I bet seeing the case was apart for Heavy Duty cam chain
Very clean inside, no burnt oil! Odds are in your favor of aftermarket pistons. The oil cooler helped a lot also.
If you can't title it? Take it to your local dragstrip and beat the hell out of it! Are you a Drag race fan? Even dirt or sand drags.
Were are you located?
Boy, I would have loved to find and buy that cycle! I had one pretty close to that 4 years ago. Sold for a nice profit! Gave me white knuckles trying to beat it up on the street.
Someone built that bike right many years ago!
Last edit: 24 Jan 2016 08:46 by z1kzonly. Reason: picture
- VMASS
24 Jan 2016 09:10
Well, that sounds good! Although, I am nota drag race fan, more of a purist when it come to bikes.
I will go take a look at the cam ends....anything else to look for?
I am 463 mile from you.
- zukdave
24 Jan 2016 10:59
Look close at #1 intake lobe it's hit the head as the cam walked to the right you can see the nick.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
24 Jan 2016 11:18
Dave might be right. Those might be high lift cams. Being it's been sitting I take the head off and put in new Viton valve guide seals and relieve that area as well. Chance to see what pistons are in there too.
- VMASS
24 Jan 2016 11:18zukdave wrote: Look close at #1 intake lobe it's hit the head as the cam walked to the right you can see the nick.
You know what is interesting, there are no other marks where other lobes have hit the head, would there be if walked right?
Also, that #1 intake lobe has a more pronounced casting than the others, stands very proud of the side of the lobe, In other words, the top of the lobe doesn't seem like it hit the head, I believe it was the casting on the side of the lobe. Make sense?
- zukdave
24 Jan 2016 13:03 - 24 Jan 2016 13:04
Not enough clearance was ground on the head.
I'd pull the head strip it and put the cams in no spring's or valve's and check all lope's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 24 Jan 2016 13:04 by zukdave.
The following user(s) said Thank You: VMASS
- VMASS
24 Jan 2016 13:41zukdave wrote: Not enough clearance was ground on the head.
Thanks. I won't get that far into it until I figure out if I can title the bike.
