1980 KZ750H Modern Cafe Project
  • afstuart
  • afstuart's Avatar Topic Author
20 Nov 2011 10:53 - 20 Nov 2011 11:53
#489318
I am starting a custom cafe build. I have started with a 1980 Kz750H and will be modifying the front ent to a 2002 Zx7 setup. I will also be adapting a 2004 GSXR600 rear end. I will post progress and difficulties as I go. Any helpful hints along the way would be most welcome. Thanks
soscycles.com
Attachment PICT0035.JPG not found
Attachment PICT0052.JPG not found
Last edit: 20 Nov 2011 11:53 by afstuart.
  • afstuart
Re: 1980 KZ750H Modern Cafe Project
20 Nov 2011 11:23 - 20 Nov 2011 11:29
#489320
The stem from triple tree off the kz was removed and the zx7 lower triple was machined flush. The kz stem was pressed into the zx stem after some machining. I pin was placed in for safety. Machining cost $150. Well worth it. Now it is a dead fit with the new tapered bearings.
Attachment triple.JPG not found
Attachment triple2.JPG not found
Attachment PICT0007.JPG not found
Attachment pict0009.JPG not found
Last edit: 20 Nov 2011 11:29 by afstuart.
  • camaroguy
  • camaroguy's Avatar
20 Nov 2011 14:22
#489343
looks good nice start
  • ramtough_63
  • ramtough_63's Avatar
20 Nov 2011 14:35
#489344
keep the pics coming love the look
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
  • porchev914
  • porchev914's Avatar
20 Nov 2011 18:38
#489363
I'm trying to figure out where you're going to sit :P What are your plans for the subframe?
FRANKEN Z!
  • afstuart
22 Nov 2011 00:36
#489631
Here are some mock up shots of the rear suspension set up. Once the subframe is designed mores support will be incorporated.
Attachment rearsuspensionsetup1.JPG not found
Attachment rearsuspensionsetup5.JPG not found
Attachment PICT0046.JPG not found
  • badrhino
  • badrhino's Avatar
24 Nov 2011 02:11
#489937
Looking good keep it coming.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • murph
  • murph's Avatar
24 Nov 2011 10:46
#489974
Really like the look off this one bud very interested to see how it goes .
Good luck
Z900A4 Z1170R ZZR1100 Z1OC 21CLUB SCOTLAND
  • afstuart
Re: cb350 tank
26 Nov 2011 20:25 - 26 Nov 2011 20:30
#490259
Well, working on the suspension set up. I got the mono shock welded and the front tank mounts made. I had to spread the cb350 tank a bit the get it to fit. Next step subframe. What is the best way to make a custom tail section?
Attachment pict0001.JPG not found
Attachment PICT0003.JPG not found
Attachment PICT0002.JPG not found
Attachment pict0005.JPG not found
Last edit: 26 Nov 2011 20:30 by afstuart.
  • hal0tw0
  • hal0tw0's Avatar
27 Nov 2011 19:37
#490406
Bitchin! I like where this is going. For ideas on a subframe, look on ebay for xxx subframe. you will get a general idea how they look and possibly mount. Then you can use stuff like coathangers, masking tape, cardboard, dowels, hell, anything you have on hand to "mock" something up. Make some drawings and get some tube and get bendin/welding :)
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
  • afstuart
04 Jul 2012 22:31 - 23 Sep 2012 13:04
#533907
Attachment tailproject.JPG not found
Attachment tailproject11.JPG not found
Attachment tailproject12.JPG not found
Attachment tailproject1.JPG not found
Well, after many hours of thinking and looking at this thing I think I have settled on the start of a tail section. I am going to add to it and incorporate a taillight. It is the cowl off a 2011 gsxr 1000. So many projects going this one is moving slow. Ride safe.
Last edit: 23 Sep 2012 13:04 by afstuart.
  • afstuart
23 Sep 2012 13:03 - 23 Sep 2012 13:07
#550389
Hello All, It's been a long time, but I am finally back on the KZ project. Began fabrication of sub-frame and tail section which is a rear scoop of a 2011 GSXR1000. I used some old metal I had sitting around the shop to fab up the sub. Complete set of shop photos can be seen @ SOS CYCLES
Attachment 2003_01019-22-20120021.JPG not found
Attachment 2003_01019-22-20120003.JPG not found
Attachment 2003_01019-22-20120009.JPG not found
Attachment 2003_01019-22-20120004.JPG not found
Attachment 2003_01019-19-200120002.JPG not found
Attachment 2003_01019-19-200120012.JPG not found
Attachment 2003_01019-19-200120006.JPG not found
Last edit: 23 Sep 2012 13:07 by afstuart.
