Z800 Cafe Fighter Chopper thing GEOMETRY SPECS
- getarun
Re: Z650 Café Fighter Chopper thing
16 May 2013 14:27
Really NICE!! Those tires kick ass und your work looks great.
:ohmy: :ohmy: :ohmy:
Need more money and a friend in a paint shop
Driving a KZ550B '83
IC-ignitor problems
IC-ignitor problems
- bluezbike
16 May 2013 14:27
Just found this thread....very nice. That Citroen paint color is really nice
79 KZ 1000 LTD
- turboguzzi
16 May 2013 15:00
make no mistake man, we are really glad you are continuing,
was just airing some steam about all those sad un-finished projects....
keep up the good work
and yes, that caliper hanger was hideous!
- royalratch
16 May 2013 15:14
I should have trusted my own instincts. The machine shop I was using at the time said I needed a single piston MotoX style caliper because of the wheels. The cleaner Brembo style caliper I wanted needs to be spaced out a but but for some reason I went with their suggestion - they were just lazy I guess.
Anyway - this calliper is now going on a way more minimal and discrete hanger. Stronger, lighter and way cooler looking. The waste of time and money for the other thing stings but I need this to be just right. Besides, maybe its worth something to someone along with the swing arm.
Like this but right side obviously.
- Ederer
16 May 2013 15:16
Great progress! Love the color!
1980 KZ650 Build
kzrider.com/forum/11-projects/552156-kz6...ect-first-time-build
16 May 2013 15:38
nice work,keep us posted.
- turboguzzi
17 May 2013 05:14
that is pretty much the caliper i use in my race bikes, if i was you, would place the caliper under the swingarm with a torque spar, racier 70's look, lower CG.
i always found that with these brembo calipers you always need to step out the hanger. i do it with two simple plates bolted together just becuase i hate spending money on blingy CNC stuff i can do myself with a saw and press drill .
if you want pics, just say yes
17 May 2013 08:50
That paint job looks like glass!
- royalratch
17 May 2013 10:45turboguzzi wrote: that is pretty much the caliper i use in my race bikes, if i was you, would place the caliper under the swingarm with a torque spar, racier 70's look, lower CG.
Not too worried about CoG lol!
I actually prefer the look mounted dead at 12'o'clock with a very discrete almost invisible bracket. This type of hanger is used on all the super bikes now as its simple, light and strong - 1-piece. Its only bling because none of the stock hangers will fit a custom and modifying one is not a good idea.
- royalratch
18 May 2013 05:39
So am in the process of having the forks sent off and serviced / set up for a slightly heavier bike. Any advice on this appreciated as always.
But aesthetically, I'm in a bit of a quandary.Originally I wanted the gold legs / black sliders look as standard on GSXRs and nwere Kawa sports bikes.
Like so:
But now I've seen the bike in the flesh, I'm thinking I might go with some black on black crime?
What's the the thoughts out there? I'm really leaning toward the black/black. Because then the gold accents will pop more and it will look more tough / unique / custom.
I'd leave the axle clamps in the brown/green so should look a very unique set of forks.
Like so:
- CruisingRam
18 May 2013 07:50
I think the black is awesome. The gold has been done to death- dare to be different man- cause this bike is prime sex right now my man! :lol:
What bike did the forks come off that you need to stiffen them up? Did I miss the post? Probably.
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
- royalratch
18 May 2013 08:13CruisingRam wrote: What bike did the forks come off that you need to stiffen them up? Did I miss the post? Probably.
2006 ZX6 Ninja. A pretty light bike compared to a Z. I'm guessing the springs won't be upto it. Should probably check the actual weights as this bike will be about 20KG lighter than a regular Z.
Forks aren't to pricey to swap but full-on custom fork internals are out of control money. Not worth it.
