'78 KZ1000 makeover
- porchev914
Re: '78 KZ1000 makeover
09 Apr 2011 14:13
I FINALLY got a battery. $75 at Walmart. Now I can make a battery box, and more importantly, the mounts for the battery box in the frame. That is one of the last frame fabrications I need to to make, besides an exhaust mount.....and passenger pegs...and I'm sure I'm forgetting something else :pinch:
I can not for the life of me find any CCA #'s on this battery or packaging. Wierd...
FRANKEN Z!
- gengomerpyle
09 Apr 2011 14:20i got my battery from interstate for a little over 50porchev914 wrote: I FINALLY got a battery. $75 at Walmart. Now I can make a battery box, and more importantly, the mounts for the battery box in the frame. That is one of the last frame fabrications I need to to make, besides an exhaust mount.....and passenger pegs...and I'm sure I'm forgetting something else :pinch:
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- porchev914
09 Apr 2011 14:32 - 09 Apr 2011 14:33
This particular battery is distributed by Johnson Controls (Interstate) but it's still made in Taiwan :blink: What kind of battery did you get for $50? This battery is a Sealed AGM battery. The last battery I got for this bike was a standard vented unit, and it was $45. I need to be able to lay it flat, hence the more expensive sealed unit. If you got a sealed AGM Interstate for $50, I'm taking this thing back and buying from your supplier!!! :laugh:
FRANKEN Z!
Last edit: 09 Apr 2011 14:33 by porchev914.
- gengomerpyle
09 Apr 2011 14:41just a normal batteryporchev914 wrote: This particular battery is distributed by Johnson Controls (Interstate) but it's still made in Taiwan :blink: What kind of battery did you get for $50? This battery is a Sealed AGM battery. The last battery I got for this bike was a standard vented unit, and it was $45. I need to be able to lay it flat, hence the more expensive sealed unit. If you got a sealed AGM Interstate for $50, I'm taking this thing back and buying from your supplier!!! :laugh:
1982 GPZ750R1 ELR
1971 Honda CB750K
1971 Honda CB750K
- mark1122
- Keep twisting it
09 Apr 2011 15:28
Yuasa shows 14bs batt's at 200 to 210 cca.
i would encourage u to compare the dimensions of yours to the yuasa's most popular 14's and if needed make your box slightly larger to make sure it fits a yuasa. this will give u more flexibility when the time comes to replace your bat .
if yours is the same dimension, u r golden.
i will email u a chart
M
M
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- porchev914
09 Apr 2011 15:28
Damn, and here I was hoping I could save $25!
FRANKEN Z!
- porchev914
09 Apr 2011 16:17
You are right Mark, it looks like it would behoove me to make my battery box an additional 1/2" longer to fit a wider range of batteries.
FRANKEN Z!
- porchev914
13 Apr 2011 18:09
I FINALLY ordered my front sprocket. I'm sure I'll kick myself later for going the cheap route, and ordering an off the shelf 17T sprocket from PMFR, rather than an 18T or 19T custom from D&G for an extra $55 :whistle: I'll just keep my open highway time to a minimum if the freeway RPM's are a little high.
FRANKEN Z!
- T_Dub
13 Apr 2011 19:12
Freeway RPM's are meh, you'll like the oomph more.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- mark1122
- Keep twisting it
13 Apr 2011 19:23
are u going with a 530 , what offset?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- porchev914
13 Apr 2011 19:52
530 pitch, 7/8" offset. When I measured my required offset, it was just shy of 15/16"
I am hoping that 1/16" out of alignment won't matter.
FRANKEN Z!
- mark1122
- Keep twisting it
17 Apr 2011 11:34porchev914 wrote: 530 pitch, 7/8" offset. When I measured my required offset, it was just shy of 15/16"
Unless u are a very talented track racer that can achieve high lean angles, 1/16" will make NO DIF. 1/4" is common.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
