'78 KZ1000 makeover
  • porchev914
  • porchev914's Avatar Topic Author
Re: '78 KZ1000 makeover
03 Oct 2010 23:29
#403934
So after cutting out the "groove" part of the mounts from the same sheet I cut the tube caps, I tacked those into place and drilled a 5/16" hole through the new joint. I rummeged around for a bolt and nut and threw in the first one I found.
After having thought about this joint for the last hour, I'm inclined to remove it in favor of a stronger design. I was going to box in the top of the tabs, which would help strength signifigantly.....But now I'm thinking I would rather move the 3/8" bracket over, and weld a matching 3/8" bracket to the subframe on the inside of the frame bracket. Then thread the subframe bracket for the 5/16" bolt. Nice and clean, simple, strong. Yeah, I think I'll do that :)
FRANKEN Z!
  • camaroguy
  • camaroguy's Avatar
04 Oct 2010 03:01
#403945
Adam, not sure I understand the purpose of cutting sub?
  • porchev914
04 Oct 2010 06:04
#403954
The subframe is now removable. Ultimately I'll end up experimenting with a carbon subframe. For now though the stock one modified will do nicely ;)
FRANKEN Z!
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
05 Oct 2010 07:45
#404165
keep up the good work. B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
05 Oct 2010 13:52
#404242
keep us posted!
i am having to earn my keep this week and haven't had much time to check in.
  • porchev914
05 Oct 2010 15:22
#404269
Leon, bro, hows that shoulder/arm healing up? Thanks for checking in :cheer:
FRANKEN Z!
  • porchev914
05 Oct 2010 17:52
#404336
OK, I'm going to put it to a vote. The tongue n' groove joint on the left.....the lap loint on the right. Which is better and why?
FRANKEN Z!
  • trianglelaguna
  • trianglelaguna's Avatar
05 Oct 2010 17:56
#404341
now just cause the other hybrid guys are wadding bikes up and getting bruises...does not mean you will need to young man
why if someone jumps off a bridge are going to follow them....
you look at me ,when i'm talking to you...well? are you?
go to your room.........
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • PLUMMEN
  • PLUMMEN's Avatar
05 Oct 2010 17:56
#404342
how about a piece of boxed tubing with the bottem cut out and beveled to match frame down tube ? B)
  • PLUMMEN
  • PLUMMEN's Avatar
05 Oct 2010 18:04
#404344
or how about sleeving it with a slightly larger piece of rd tubing with the bottem opened and sides straightened along bottem and end beveled to match frame downtube?
you could even take a piece of 12ga and wrap it around the existing tubing to acomplish the same affect easier B)
  • PLUMMEN
  • PLUMMEN's Avatar
05 Oct 2010 18:05
#404345
i wish i knew how to draw pictures on a computer! :( :laugh:
  • porchev914
05 Oct 2010 18:18
#404350
Following others off a bridge??? NEVER!!! I'm the first one in line :laugh: :laugh: :laugh:
FRANKEN Z!
