'78 KZ1000 makeover
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
Re: '78 KZ1000 makeover
05 Aug 2013 11:09
#599916
i copper coat base and head gaskets usually.
unless i have some kind of a good reason not to.
like the gasket has sealer made into/onto it.
nice progress keep up the good work.
  • porchev914
  • porchev914's Avatar Topic Author
05 Aug 2013 13:05
#599928
Thanks for the kind words my friends :) Considering Leon has built a bajillion engines, Josh is every bit as picky as I am and powerstrokes' experience, I think I'll get a can of copper coat. The last thing I need is oil leaking on my brand new bike!
Now Leon, is the copper frame so terrible? I know it's not black, but it's gotta be a close second :P
FRANKEN Z!
  • porchev914
06 Aug 2013 03:42 - 07 Aug 2013 09:24
#600058
OK, pistons on:
I did copper coat the base gasket, and will likely treat all the gaskets the same.
Then went on the cylinder, which by the way, was a PITA. I put the head on just to keep it closed up. I did lay the tank back on it to see how it would look.
I didn't take pictures, but I replaced the center cam chain roller in the block and its rubber dampers with new OEM parts. I also replaced the rubber tensioner roller and the front plastic rubbing block with OEM parts as well as the idler gear rubber dampers. I did not replace the idler gears, as they seemed to be in good condition with no slop and smooth bearings.
The head is going to come apart so that I can replace the valve springs and stem seals. While its apart, I will clean up the intake ports a little and smooth out the exhaust a touch. Just blend things in a little, nothing crazy or drastic.
Tomorrow I'll put the subframe and battery box on, then it'll look more like a complete motorcycle.
FRANKEN Z!
Last edit: 07 Aug 2013 09:24 by porchev914.
  • 531blackbanshee
  • Vendor
06 Aug 2013 10:10 - 07 Aug 2013 10:10
#600078
man i don't know what to think about all this progress :evil: !
dayum son you been getting some work done.it's almost like you are planning on finishing this project up or sumthin :whistle: .
yeah the copper is better than blue,red,yellow,or green thats for sure.
it kinda goes with the forks too :P ...
we are watching you sir ...
Last edit: 07 Aug 2013 10:10 by 531blackbanshee.
The following user(s) said Thank You: porchev914
  • Ederer
  • Ederer's Avatar
06 Aug 2013 10:56 - 06 Aug 2013 10:58
#600082
Looking great!
I tend to use copper spray on anything cometic on my automotive projects, and have had good luck. I think the trick is really in surface prep but your work looks immaculate so I would bet you will have zero problems once this beast is assembled.
Last edit: 06 Aug 2013 10:58 by Ederer.
  • loudhvx
  • loudhvx's Avatar
06 Aug 2013 11:03
#600084
Looking good! Those tear drop nuts do seem to vanish without a trace. The ones my buddy made look exactly like yours. B)
06 Aug 2013 13:04
#600099
Things are starting to come together, looking sharp!
78 Kz1000A2, 77 Cb750K daily rider, pinstriper and signpainter
  • DesertKZ
  • DesertKZ's Avatar
06 Aug 2013 18:32
#600127
Beautiful!
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
  • rich67
  • rich67's Avatar
07 Aug 2013 21:59 - 07 Aug 2013 22:01
#600342
Very nice ,at first i thought the copper was a little odd. With it assembled it realy looks great. blends with the forks well also looks bad ass with the swing arm (nice work) , whats the size of the engine?
Last edit: 07 Aug 2013 22:01 by rich67.
  • porchev914
07 Aug 2013 23:24
#600352
Trust me, the frame color was a gamble! :whistle: Thanks for the compliments too B) The engine is an otherwise stock 1075.
I was dead to the world yesterday, and didn't set foot in the garage. Today I'll get that subframe and a kickstand on the bike and drag her out into the street for another pic.
FRANKEN Z!
  • 531blackbanshee
  • Vendor
08 Aug 2013 09:33
#600383
like pics with the sub frame and tailpiece sitting on it maybe ? :evil:
  • porchev914
08 Aug 2013 16:52
#600456
531blackbanshee wrote: like pics with the sub frame and tailpiece sitting on it maybe ? :evil:
Maybe Leon....just maybe... B)
The ugly left side (the tank that is)
Right rear view
Right side view
I did not modify the kickstand or the mount in any way, and the amount of lean on the kickstand isn't far from stock. Overall I'm pleased B)
FRANKEN Z!
