'78 KZ1000 makeover
- porchev914
Re: '78 KZ1000 makeover
24 Sep 2011 23:16
Keep in mind guys, I have her on jack stands, so its pitched
down a bit more than it would normally be. But I think I'll
keep this amount of tail lift, and weld the tabs up. I am
inching closer to getting the frame fabrication stuff done.
Next is reinstalling the sidecover tabs I just cut off to
install the threaded tubing ends :whistle: It seems to be
a never ending cycle, doesn't it? :laugh: Damn butterfly
effect or some crap :woohoo:
FRANKEN Z!
- porchev914
24 Sep 2011 23:25ramtough_63 wrote: I know exactly what you mean by the way love the "franken Z" you should incorperate that into the paint scheme.
I have something special planned for the paint; I want a classic 74/75 Z1 paint scheme with the main color being the black of the composite, then "ghost" the paint over it, so from afar it looks painted, but up close you can see the weave through it. I may not be able to pull it off the way I want, I'm getting some negative reinforcement from the local paint supply stores. Perhaps I should call H.O.K. and see if they have the same "can't be done" story. Humph!
FRANKEN Z!
- fxdl2051
25 Sep 2011 00:20
That paint job will turn some heads, sounds impressive. "Franken Z", I love that name.
- ramtough_63
25 Sep 2011 00:36
my paint isnt perfect by no means but I have got alot of that when I was putting together my sceme. now that I know more about these new paints there is nothing you cant do if you can imagine you can do it. one way is to tint your clear with couple drops of black I havent looked but if HOK has black pearl when the sun hits it you look blck when you are up on it you are whatever color your base is I cant wait to do my next set my son works for his mother at the bodyshop
and instead of buying blackout lenses for his rides he paints them with tinted clear
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
25 Sep 2011 01:34you like this because it looks like aircraft sh!t !!!!!!!!!
it really does look clean.
are you feeling salty with that tig?
lookin good adam,glad that you have gotten some garage time.
ramtough you need to post some pics of that goldwing,i kinda got a soft spot for wierd wings.
- porchev914
25 Sep 2011 05:13
The problem with doing what I want with the paint scheme is the black base of the tank. I want a deep pearl red for the main stripe on the sides of the tank with pearl white trim, and an accent stripe along the bottom thats the same dark bronze the frame and forks are going to be. But with the black base, it signifigantly darkens the colors. For example, alot of the pearl colors are 3 stage, meaning you have a straight color base coat (like red, for a red pearl), then the pearl coat followed by the top coat. Because I want to see the weave of the fabric, I cant have that 1st stage, since thats the background the paint needs to look right. If I use a basic 2 stage pearl, the color won't show up right bacause of the black background. If all else fails, then I will do the paint scheme I want, it simply won't be ghosted. But it would be 100X cooler if I could pull it off! :woohoo:
Leon, thanks for your support and unwavering dedication to quality
Aircraft sh!t is cool! What the hell is "salty with a tig" anyway? I can't figure out if its a compliment or an insult :laugh:
Group ride tomorrow....I am in desperate need to recharge the ride tank to refocus my priority on getting this finished.
FRANKEN Z!
- ramtough_63
25 Sep 2011 12:30
I see what youe saying with the pearls and the tri coat mygrean is a tricoat pearl with silver metalflake base I didnt use the silver metalflake on the front fender or headlight (just primed em grey then shot the midcoat then clear
. its not alot different but the depth isnt rhere on the fender and headlight)I need to ponder this Where theere is a will there is a way
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- ramtough_63
25 Sep 2011 12:34Attachment 30383.jpg not found
Had to relocate few frame supports for the actual carb to fit. remount the coils remove the center golovebox (Like I donrt have enough storage) but it makes a snap for carb adjustments have it off and back on in 10 minutes
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
26 Sep 2011 11:27 - 26 Sep 2011 11:42
adam,
in the old west when they said that someone was
"pretty salty with a gun",
that meant they were very good and that you did not want to mess with them.
welding is one of those things that takes alot of "feel".if i haven't been welding regularly it takes me a few passes to get to feeling "salty" again.
so i guess the way i used it basically was the same as saying
"are you feeling pretty cocky with that tig?"
Last edit: 26 Sep 2011 11:42 by 531blackbanshee.
- testarossa
26 Sep 2011 11:36
Time to start welding razor blades together.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- porchev914
26 Sep 2011 20:11
Maybe a little cocky Leon
thanks for the compliment, I should have known. I've never seen you insult anyone on the forun buddy
Also, thanks for the history lesson :woohoo: .
Josh, I did try a couple times months back to weld the cutting edges of single edge razor blades together. MUCH too difficult for my skill level.....The steel burns back too easy :whistle: :laugh: My welder will go down to 5 amps....I think thats low enough to do razor blades. Perhapes its time to give it another try
FRANKEN Z!
27 Sep 2011 18:06
