'78 KZ1000 makeover
- porchev914
Re: '78 KZ1000 makeover
20 Sep 2011 20:51
Pictures would be great Craig. I am of the opinion that the failing part/material is of an inferior quality, or is obviously not up to the load/cycles required of it in service. I have subjected rod ends to much more stress that a motorcycle shifter, and OEM parts on new bikes don't seem to have any problems, so there must be something else going on. Some pics of the failed part
FRANKEN Z!
- trianglelaguna
20 Sep 2011 20:59
k...chillin now and all is put away ...the last one easy outed in 3 seconds...i agree and just before logging on was doing a mental cad on the screw bit...it is crystal in comp at the twist off where it deforms/twists...simple thing for me to take to welder with about a dozen nice same thread options and have him clip and tack the right strength threads to mate to the spline knuckle....i wonder how many tarrozzi sells of this item...ect...pics for sure after i put the third one on
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- porchev914
20 Sep 2011 21:03
At least you have a replacement. I liked those tarrozi rearsets, its a shame that part of the shifter seems to have a MFG. defect
FRANKEN Z!
- trianglelaguna
20 Sep 2011 21:19
they are fun and about 50/50 over stock and 100 percent worse than my home made ones for riding around more than 15 minutes...they get small after a bit... imo when you take off the rosey glasses..
at a stand still for a conversation piece
and for a nice single up no monkey riding your legs/warden..... haul ass ,,,they are 101% era correct maybe some safety wire and they would grace a nice proj and haul ass.....but get grumpy after an hr ect... i ride em to work and they are 5 rider 10 parked...
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- porchev914
20 Sep 2011 22:48
Comprendo; Look great, but feel less than stellar after 10 minutes. Still, shouldn't be failing :dry:
FRANKEN Z!
- porchev914
21 Sep 2011 02:28
I was working on some tid bits this evening, and thought I'd snap a pic. Just because. I haven't taken a full bike pic in a while. Not much has changed since the last time I took a full bike pic except for the battery box.
One thing I had to accept this evening is that I can't use the R6 rearsets
The master cylinder mount doesnt clear the frame, and I'd have to space it out too far to make it work. So I'm back to the drawing board on the rearsets. Fortunately, it shouldn't affect my time table (as if I have one) for getting the frame finished and painted.
FRANKEN Z!
- camaroguy
21 Sep 2011 06:54
is there somewhere on the tarozzis that you can drill a hole and mount some small heim joints? or maybe weld a small tab?I bought some for mine from a local drag race shop. they seem to work pretty good.I ride mine pretty much everyday.still hangin
- porchev914
21 Sep 2011 23:05
Here you go Leon, those tubing adapters showed up today :woohoo:
I didn't anticipate the adapters to be so long! 4" is alot of realestate at the front of the subframe. I'll definately need to remove and reinstall the right front sidecover mount, maybe the left; haven't checked yet. Oh well, whats R&Ring a small bracket for a nice clean clevis mounted connection? One of the few corners I cut, and LEON calls me on it
There you go Leon, almost resolved
p.s. you were right, I couldn't let it slide
FRANKEN Z!
- testarossa
21 Sep 2011 23:26
I can't tell about the tubing adapters, but the clevis's definitely look cadmium plated to me. Make sure you have adequate ventilation if you are welding on that stuff. The vapors ain't gonna do you any good.
No R-6 rearsets?
Now you'll have to affix a new bracket for the contraband.
No R-6 rearsets?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- porchev914
21 Sep 2011 23:55
I know, I'm bummed about the rearsets too, as well as my contraband holder
The clevis's are cad plated, but they won't be welded on, thats what the tubing adapters are for bud
The clevis threads into the adapter which is welded to the subframe, and bolts to a small 3/8" bracket welded to the main frame. Simple and clean.
FRANKEN Z!
- porchev914
22 Sep 2011 01:25 - 22 Sep 2011 01:28
Top subframe mounts; The UGLY right side:
The BAD left side:
The GOOD replacement tubing adapters and clevis's
Hopefully tomorrow I'll get the adapters tig welded to the subframe and the new frame tabs cut and shaped.
Don't know why I tried to stick in a Clint reference
The BAD left side:
FRANKEN Z!
Last edit: 22 Sep 2011 01:28 by porchev914.
22 Sep 2011 10:12
fine blame me :pinch: .
although i really don't have any remorse for shameing you into kicking it up a notch
i absolutely loved the clint eastwood reference. :kiss:
the clevis's and tube ends give it a nice clean look.almost like you meant to do it that way from the start
i want that to be my hillbilly name,
CLEAVIS.
haha,
keep up the good work,
CLEAVIS.
haha,
