  • Page:
  • 1
Cam Chain Tensioner 01 May 2024 06:32 #898283
  • 78kawltd
  • 78kawltd's Avatar Topic Author
  • 1978 B2, 06 Heritage Softail,
  • Thank you received: 23
Re: 78 kz1000 b2 ltd.
The factorty service manual reads as..after the basic TDC task..loosen locknut.  Turn Out the bolt several turns..Tighten locknut.  Hmm ?
What happened ?  Is that it ?
Cam Chain Tensioner 01 May 2024 06:45 #898284
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 667
We don't have a KZ1K manual to refer to.  The Z1 motor is pretty much identical to the KZ1K motor in this respect.  Camchain tensioning is also described in the Z1 Owners Manuals.  It may be published in the KZ1K Owners Manual if you have it.
The Z1 FSM manual reads as follows:
Loosen the lock nut and bolt. (With the bolt loose, a spring inside takes up the slack automatically.)
Turn the engine over a couple of times so that slack is taken up evenly on all parts of the chain.
Tighten the bolt, then the lock nut.
We use a minor variation of this.  We also do this when hot.  Whatever method you use, do not leave the bolt loose.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
The following user(s) said Thank You: 78kawltd
Last edit: by slmjim+Z1BEBE.
Cam Chain Tensioner 01 May 2024 08:39 #898293
  • 78kawltd
Thank you.  Yes. I had paraphrased ( since I didn't have access to the FSM)
Here are the FSM specific KZ1000 instructions I used. See attached please.
The 1978kz1000  FSM instructions appear to be different from your helpful info.
Cam Chain Tensioner 01 May 2024 09:31 #898298
  • 78kawltd
Adding that, ironically the information from my personal 1978 kz1000 FSM reads different than the KZR download version.
(Kawasaki KZ 1000 (A2A-A3A_MKII-A4-D3_Z1R) '76 thru'79 - Service Manual.pdf)
I'll locate, re-read and plan to share. Standby please.
Thanks again.
Cam Chain Tensioner 01 May 2024 14:52 #898309
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1939
You can modify the cam chain tensioner into a manual adjuster.
The mod allows you to adjust the cam chain tention under engine runing in idle condition.
www.kzrider.com/forum/2-engine/575505-ho...ain-tensioner#575852
Cam Chain Tensioner 01 May 2024 20:12 #898320
  • RonKZ650
  • RonKZ650's Avatar
  • Thank you received: 239
Yes, that is it. Loosen the bolt, spring tension takes up chain slack, then you tighten bolt to lock the tensioner from backing off. It's a good reliable system for 150,000 miles. The advantage beyond being fool proof is the tensioner has much more adjustment range to work vs the newer full auto tensioner they used later.
  • Page:
  • 1
