Plastic Safe Paint Stripper
  • Shoey949
  • Shoey949's Avatar Topic Author
20 Jan 2006 17:34
#18978
I need a paint stripper that won't melt plastic side covers, I'm tired of sanding. Any suggestions?
Thanks,
Nate
'83 GPz550H2 w/'81 GPz 550D1 engine
Dynojet Stage 3 kit, MAC 4-1, UNI Pods, DYNA coils and plug wires, WG ignition mod
Grand Rapids, MI
  • KZ_Rage
  • KZ_Rage's Avatar
  • Kentucky Bourbon Barrel Ale
Re: Plastic Safe Paint Stripper
20 Jan 2006 17:57
#18981
Post edited by: KZ_Rage, at: 2006/05/16 12:07
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
  • wireman
  • wireman's Avatar
20 Jan 2006 18:26
#18988
i was jacking around onetime and tried some acetone fingernail polish remover i figured it comes in a plastic bottle what could it hurt?boy did i have a wrong number!bwaha:whistle: i forgot about the part and left it soak overnight when i came back the acetone evaporated and there was a plastic blob where my part used to be!:S good luck happy wrenching!
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
20 Jan 2006 18:49
#18993
I've had goog luck with any DOT 3 brake fluid. It'll not attack the plastic and will easily remove any painted on finish. Just set up some sort of tray to set the part in. pour in as much brake fluid as you can spare and immerse the part. It's not necessary to cover the whole part as the brake fluid clings pretty well. Just turn it occasionally. It may well take three of four days but IT WILL WORK. I've sucessfully removed paint from the inside of tail light lenses without dulling the surfaces.
KZCSI
I believe that most plastic side covers are ABS. While I've never tried to disolve the paint from a side cover, I have used an ABS tray to soak other parts in brake fluid with no ill effects.
Post edited by: KZCSI, at: 2006/01/21 09:33
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • Shoey949
20 Jan 2006 20:58
#19007
Any clue where you can get that ELO stuff at?
Grand Rapids, MI
  • KZ_Rage
  • KZ_Rage's Avatar
22 Jan 2006 14:36
#19310
Post edited by: KZ_Rage, at: 2006/05/16 12:06
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
  • fonZee
  • fonZee's Avatar
22 Jan 2006 18:30
#19348
Do not put chemical strippers or solvents on plastics. If you are not careful you will damage them. They can absorb solvents and it will soften them or distort them. Just sand them for the safest results. Takes longer but easier to prep and finish.
  • mykznme
  • mykznme's Avatar
22 Jan 2006 18:36
#19352
you dont have to go all the way down to the plastic.
just sand it smooth.
for deep spots sand the surrounding area and use model plastic filler,be sure to dig the paint out of the scratch or hole.
R.I.P. Odd Ivar
  • wireman
  • wireman's Avatar
22 Jan 2006 19:20
#19374
side covers and tailpieces are actually pretty wavy out of the box,a good stiff blocksanding makes them look a lot better!B) goodluck,happy wrenching!
  • The Fish
  • The Fish's Avatar
23 Jan 2006 06:00
#19444
My experience with brake fluid and plastic is the plastic asorbs some brake fluid and is very, very hard to remove and paint over with out getting fisheyes.
Sanding would be the best bet.
Fish
  • KZ_Rage
  • KZ_Rage's Avatar
23 Jan 2006 09:40
#19478
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
  • Shoey949
24 Jan 2006 15:08
#19709
well unfortunately I already began using brake fluid. So now what can I do to neutralize its effects? Will simply sanding the top layer of plastic due the trick?
Thanks,
Nate
Grand Rapids, MI
