530 to 520 Sprocket Advice
  • pbmax
  • pbmax's Avatar Topic Author
31 Oct 2013 14:35 - 08 Nov 2013 14:17
#611742
1979 KZ750 B4
Stock is 530 16t/38t, but I would like to convert to 520 17t/34t.
I'm 99% sure the following sprockets will fit:
www.jtsprockets.com/catalogue/sprocket/JTF565-17
www.jtsprockets.com/catalogue/sprocket/JTR1478-34
I know the teeth on the 520 sprocket are thinner, but is the whole sprocket thinner or just at the teeth? Will I have to add any spacers or something like that?
Thanks!
Last edit: 08 Nov 2013 14:17 by KZQ.
Re: 530 to 520 Sprocket Advice
31 Oct 2013 14:46 - 08 Nov 2013 14:18
#611743
The 520 chain is narrower than the 530 chain. The "3" in the "530" chain stands for 3/8" width, and the "2" in the "520" chain stands for 2/8" (1/4") width. Here's a link to a chain size chart that might help. Ed
www.dansmc.com/ek_chain_specs.jpg
Last edit: 08 Nov 2013 14:18 by KZQ.
  • pbmax
31 Oct 2013 15:30 - 08 Nov 2013 14:18
#611752
Let me rephrase...
I know the teeth have to be narrower to fit the 520 chain, but what about the rest (center part) of the sprocket? Same thickness as a 530 one? I'm just wondering if I need to add spacers to keep everything lined up as it was in the stock configuration .
31 Oct 2013 16:51 - 08 Nov 2013 14:19
#611757
Ah, now I understand the question. As long as both the front and rear new sprockets are the same thickness it shouldn't matter (unless the chain rubs on the frame or tire which is unlikely). They should line up ok since the centerlines of both sprockets will be just a little bit closer by the same amount to the centerline of the bike. Ed
Last edit: 08 Nov 2013 14:19 by KZQ.
  • BlackZ1R
  • BlackZ1R's Avatar
  • Kawasaki in my blood
01 Nov 2013 19:10 - 08 Nov 2013 14:19
#611864
Unless there are some offsets manufactured into the new 520 sprockets, they will line up just like the factory sprockets did. How can they not be lined up? They are both mating up to the same mounting surface that the 530 components mounted to. The "back" side of the chain will be in the exact place that the original 530 was.
Your gearing choices are going to gear your bike way higher than stock. It will be very noticeable pulling away from a stop.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
  • 0Z.Z1R Mk2
  • 0Z.Z1R Mk2's Avatar
01 Nov 2013 22:41 - 08 Nov 2013 14:20
#611879
Here is a link that some here maybe interested in, from our Aussie Kawasaki guru....
Although it covers Z1000A1 - A4, Z1000D1 (Z1R), Z1R MkII, Z1000MkII, Z1000H only.
I have done this 520 conversion to my Z1R.
ksrc-au.com/phpBB3/viewtopic.php?f=31&t=...08&hilit=520#p608008
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
Last edit: 08 Nov 2013 14:20 by KZQ.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
04 Nov 2013 11:43 - 08 Nov 2013 14:20
#612056
pbmax wrote: Let me rephrase...
usually the sprocket is the same thickness from spline to tooth.
but,
not always.
sometimes the splines are wider than the rest of the sprocket and teeth.
it will be obvious if you see a pic of the sprocket.
if you do not have sufficient sprocket thickness at the splines it can be made up with a custom spacer or washers stacked up.
hth,
  • sbc1320
  • sbc1320's Avatar
08 Nov 2013 13:08 - 08 Nov 2013 14:21
#612520
So my old KZ1000 came to me with I believe newer stock 630 chain and sprockets. Going to a 530 gains me what? Less parasitic drag and loss of hp due to the rotating mass?
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
Last edit: 08 Nov 2013 14:21 by KZQ.
08 Nov 2013 13:57 - 08 Nov 2013 14:22
#612527
The weight differences between X-ring and O-ring chains will differ some, but as a general comparison -
a 102 link 530 non-oring EK brand chain is approximately 63.75 inches long and weighs about 3.75 pounds.
a 85 link 630 non-oring EK brand chain is approximately 63.75 inches long and weighs about 4.78 pounds.
So the weigh savings is roughly 1 pound for the 530 vs 630 non-oring EK brand chain, and considering that it takes power to put and keep the chain in motion and to stop the chain - every pound counts. Ed
Last edit: 08 Nov 2013 14:22 by KZQ.
  • pbmax
12 Nov 2013 15:07
#612913
I went with a JT 520 36T rear sprocket. They dont make one for kz750 b4, but the do for a Polaris ATV that matches right up. Model JTR1478.
  • zukdave
  • zukdave's Avatar
12 Nov 2013 17:03
#612920
1/4 mile a 630 to 520 chain swap will show up on a time slip.
Lighter chain also help's with braking.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
