  • Page:
  • 1
Next up: replacement for Kawasaki's flexible clamps? 21 Feb 2024 11:58 #895493
  • chopper1963
  • chopper1963's Avatar Topic Author
  • Thank you received: 7
No longer avail Kawasaki part number 92037-1069
What have others used to hold the wiring harness in place, etc
Next up: replacement for Kawasaki's flexible clamps? 21 Feb 2024 12:01 #895495
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
Next up: replacement for Kawasaki's flexible clamps? 21 Feb 2024 12:43 #895496
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 370
Zip ties
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
Next up: replacement for Kawasaki's flexible clamps? 21 Feb 2024 13:23 #895500
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1789
If you want it to look correct you could use 1mm flat stock and "shrink wrap" it
Next up: replacement for Kawasaki's flexible clamps? 21 Feb 2024 14:51 #895503
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2678
Next up: replacement for Kawasaki's flexible clamps? 21 Feb 2024 15:00 #895504
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 247
If it shows, I would use Wookie's and Nessism's suggestions.  If not visible I use zip ties.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Next up: replacement for Kawasaki's flexible clamps? 21 Feb 2024 19:04 #895511
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
  • Thank you received: 223
I use 1/2 wide black Velcro tape that comes on rolls. Fuzzy side towards frame/wire.
Next up: replacement for Kawasaki's flexible clamps? 21 Feb 2024 20:01 #895512
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1859
Next up: replacement for Kawasaki's flexible clamps? 22 Feb 2024 05:12 #895515
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1623
That part was used on a bunch of Kawasaki models up to at least 2005, so there ought to be plenty on ebbay. At partzilla click the part number for the cross-reference.  I only searched by part number and found a few reasonably priced on eb. other searches should yield more results.
Used item #385222458990 was the cheapest I saw: $5.25T + tax for 3. should clean up fine. dremel w fine/soft wire wheel on the metal and silicone spray lubricant on the plastic. I like the liquid wrench silicone spray.
Also, there are Kawasaki & aftermarket band clamps that come in various sizes/lengths. see chassis electrical diagram.
New aftermarket. #394440473860. universal 8-pc kit. $15T. cheaper is probably available.
Last edit: by martin_csr.
Next up: replacement for Kawasaki's flexible clamps? 22 Feb 2024 10:42 #895522
  • OKC_Kent
  • OKC_Kent's Avatar
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
  • Page:
  • 1
